SOURCE: Wiring hard start capacitor in GE refrig
I would go back to person who gave that advice because just the right touch on that capacitor and YOU my friend will be in the hospital. If this is helpful, please post as such. TY
SOURCE: Don't panic, but I have a question about my 40
When you say relay I'm assuming the contactor. Does it shut off again when you let go of the contacts (relay)? Most likely it's low on refrigerant and the low pressure switch is shutting it down.
SOURCE: Compressor problem, installing the Supco 3-in-1 Relay
Hi, If the 3 posts are top center and bottom right left, the black wire goes top the top center post. The red wire will go to the bottom right and the white goes to bottom left.
If the posts are bottom center and top right left, the black goes on bottom center and the red goes top left. The white goes top right.
If you do not see a capacitor, disregaurd the wires in the 3-1
I hope this helps you. Please let me know if I can assist you further.
Vic
SOURCE: I have a dometic roof air on my RV, The start
Yes. Use all the replacement parts. Your compressor is hard starting due to increased tork and wear. That is what burned out the original cap.
SOURCE: Easy Start Capacitor
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
