SOURCE: JVC KD-AVX1 parking break
your car probably wont have one this wire is designed to be hooked to the park brake switch wire so you cannot watch movies going down road.as this is illegal. the wire gorunds when park brake is pressed. splice it into the wire on brake
SOURCE: have a jvc camcorder turn on and it says safe mode remove battery
Forget the battery, the mini dv carrage assy can get out of sync and initiate the safe mode, if you noticed a problem loading the tape or have heard a gear skip sound thats the problem. The best you can do with those camcorders is keep the tape in the camcorder!!!!! That will prevent the problem and insure many good years of recording.
Sorry,
Tim.
SOURCE: My Jvc Compact Camcoder (GR-SXM26EA) is stuck in safe mode
thats a hardware problem .u must to open that camera and remove mechanisum u can c there is a small board behind that mechanisum .remove that board and c there is rubeer which connec to caption motor . that u put right condition than it will work
SOURCE: jvc kw-nx7000 not working after I tried to update the firmware
I just performed the update as well and ended up with the same issue. I'm hoping to drive my vehicle around to see if it will eventually detect the satellites.
I might recommend a couple of things. Not sure what JVC Support has recommended but you can try a hard reset. Button is located on the left bottom corner of the unit.
You could also attempt a factory restore. The option is located in the settings under your navigation menu.
Overall I like the unit as it seems to be a stable system., for customization and information related to what JVC considers to be propritory info absoultely sux!!! The backgrounds are hokey and screens could really use an overhaul. I have yet to find any really great solutions for working with the files and information and have started to learn on my own. Very slow going so far as I really don't want to brick the unit. If you or anybody else has a good solid recommendation other than the obvious for working into the file structure etc... please feel free to share!
