SOURCE: RAZR V3XX - sends my texts as MMS, rather than SMS...
I had this same problem and called Motorola for support. The solution is to clear text/mms message inbox and outbox. The default setting on my phone was to never clear the inbox but I changed that to remove messages when they are 10 days old, I have not experienced the problem since.
SOURCE: Phone Sending MMS Messages as Default
The phone allocates a certain amount of storage for messages on a whole. Even though there may still show space available for text messages, you have hit an invisible "limit" and the phone is now defaulting to MMS messages because there is "room" there. Delete a fair amount of messages and you should be able to start sending regular text's again.
SOURCE: text messaging
erase your inbox and outbox messages. Change the settings to remove messge after 10 days or less.
SOURCE: Text message won't send.......Sony Ericsson Z750a
I had a similar problem when dealing with my own phone of the same type. The only permanent solution is to engage the master reset which you can find in the settings folder. A temporay solution is to go to your outbox, and you'll have a message that either has a little red x on it or just is a plain letter shape. if you try to delete this it will say one or more messages can't be deleted. make sure you change it's status to canceled, then select it choose send to drafts. make sure there are no messages in your outbox and only the one message you just moved to drafts in that folder. it still will npot allow you to delete the message. remove your battery while the phone is still on. replace reboot go to drafts and you should be able to then delete the message from drafts. if you still can't the only option i see, which is what i did, is to use the master reset
