SOURCE: Can't find Comcast remote code for Magnavox television 15MF605/17
Not every remote will control every TV. You basically have 3 options. 1) Call Comcast and see if they have additional codes not listed on their website/documentation 2) Call Magnavox and see if they have additional codes that might work with your remote. 3) Buy a 3rd party remote that works with both your comcast box and your television.
SOURCE: No power, TV set just died after 1 year, brought brand new.
my samsung tv has been by lightening ( model tx-t2782) what are the steps to testing voltages in different areas.
EMAIL: [email protected]
SOURCE: remote for disney princess p1300ntv television
Try Remotes.com to buy the original remote,will never worries about codes again.This tv was manufacturer by some small company for Disney corporation,that why very hard to get the universal codes to when the tv is old.
SOURCE: doesn't heat anything
It sounds like the micro generator has died.
Yes, you should buy a new one as the cost of repair is likely to be high.
Testimonial: "Thank you for your quick response!! I truly appreciate it!!"
SOURCE: Magnavox 19" TV shuts itself off.....won't stay on
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV
up(warranty was up of course) and found several bad capacitors.
Phillips and several other companies were sold capacitors that although
were highly rated failed within 5 years because of a lack of
preservatives. All sorts of electronic equipment is now being effected
due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
