Checked thermal fuse, door switch and start switch all good. Timer runs but no other noise.
Make sure door is closed and then if that doesnt do it, open door and look for where the door contacts at closing you will see a little metal table that is like a ground sometimes when a dryer door is closed or slammed the tab might get pulled backwards with the opening of the door again adjust the tab again so contact with door when shut makes contact if that doesnt do it, check your breaker and see if the breaker was tripped too
SOURCE: DRYER
The thermal cut-out is located on the side of the heater housing assm. To gain access you need to use a putty knife to depress the two spring clips between the top and the front panel and raise the top. The heater is on the back wall. The part number for the t-stat and thermal cut-out kit is LA-1053 and is about $20.00. Don't forget to clean your vent, and check your blower assm. Either one could have caused the problem.
SOURCE: Whirlpool LER5644A No heat and motor wont Turn
Replace the dryer wires.
Put your meter leads into the 4&5 slots.
Make sure the door switch is closed or jumpered.
Push the start button.
If you read no voltage the issue is with the wiring, the timer, or a relay.
2 more things could be wrong,check the blower box to see if you have a thermister thermostat on it,check that with your omns meter,the other thing is the motor is no longer strong enough to turn the drum and it heat up and tips off,let me know what you find-mike
SOURCE: Dryer won't start, checked thermal fuses and start switch.
It sounds like you have been through most of the areas too look.
One thing to make sure of is that you have a full 240 volts. An electric dryer can measure 120 volts. from L1 to common and 120 volts from L2 to common but you also need to make sure you have 240 volts from L1 to L2 on the meter, one leg of the breaker or one of the two fuses could be blown.
If this is alright you only have a couple components left. The timer contacts and the drive motor. Either of these could be causing the issue.
To check the motor with the power disconnected check for continuity between switch terminal 5 and the Green(black) wire on the motor. If you have no continuity the motor is bad. Check for continuity between the terminal 6 and the yellow wire on the motor, if you have no continuity there the motor is bad. Check for continuity between terminal 1 and 2 on the motor if you you do not have continuity the motor is bad.
The timer should have continuity between the Yellow and Grey wire terminals for the motor to start.
I hope this helps
Testimonial: "Great advice, thank you for your help."
SOURCE: whirlpool dryer wont start
hello theres a long pin that sits inside the door make sure it has not snaped off if thats ok then the trouble may be caused by the capacitor next to the motor white cyilnder with couple of wires coming off
regards
shaun
Not the door switch. Took it to our appliance guy and found out it was the timer. Even though the timer was running down it was not making the contact to switch the dryer on.
