I can only suggest, at this time, to try and trouble shoot your issue(s) via traditional procedures. In most all cases, a wiring diagram can get you thru most troubles. So sorry I can not be of any further help. I also tried to location info on the internet and struck out at every turn. Let me know if I can be of any possible help. Good Luck!
SOURCE: Kenmore Upright Freezer Model 253-9280810
is it possible the door has not been closed at some point?
If so they can build up with ice in the evaporator which the defrost system cannot handle....Try a manual defrost.
Depending on where the unit is installed high ambient temperature can drop the internal temp enough to set the alarm off though they will still freeze sufficiently
SOURCE: Owners Manuel for Kenmore Deep freezer
This link will take you to your owner's manual. You can save it as a pdf file
http://www.managemyhome.com/mmh/owner_manuals/search?query=253.9280412
SOURCE: Kenmore upright freezer alarm sounds constantly
replace the battery in the grill or the hi-voltage control under the unit in the back
SOURCE: Kenmore 253 9280413 freezer keeps running
The coils are embedded in the outer walls and will make the cabinet feel warm outside when the compressor is running. It needs about 4 inches of clear air space around all the outer case walls to properly get rid of its heat. If you have items stored too close to the outer walls they will act as insulation to keep heat from being dissipated. This can cause long run times.
A unit that has lost freon gas due to leakage, while unlikely, can also extend run times. Normal temperature should be about Zero when the dial is set to halfway.
Good Luck
SOURCE: Sears Ken Elite upright freezer model no 25329082991 temp alarm
alarm should go off when freezer reaches minus 18c or lower.
escalate...
Sears is not as ACTUALLY pathetic as they ALLOW THEMSELVES to appear...
But do it SOON... SEARS stores are quickly vanishing from our area.
Lethargic, incompetent... P-Poor Mgmnt…!!
SERIOUSLY...!!
