SOURCE: Dishwasher stuck on "drain"
not easy to fix - it has a leak. the tray at the base is full of water which ooperates a float which switches drain pump on. remove front panel at bottom front and mop out water or tilt backwards 45deg and water will run out. leak is usually main pump
SOURCE: Neff S5555 - empties water but stuck in draining mode.
if this machine uses an electrical-mechanical timer with cam switches, the try oiling the shaft bushings both for the timer motor and cams-the timer may be getting stuck because of dry or corroded bushings
SOURCE: Bosch dishwasher is stuck on drain cycle
cause is water in the bottom tray which operates an anti-flood switch and all machine will do is drain.
disconnect from mains
remove bottom panel and mop out water and it will work. if fault re-occurs, then you have a leak which you will have to identify
SOURCE: NEFF DISHWASHER S5443 STUCK IN TEST MODE
First try disconnecting the unit, completely from any power, for an hour or more, look in any control doors or access points for a small battery mounted to a board or in a holder, if you find one, take it out also, noting the positive and negative orientation.
If that doesn't do it, there are reset buttons under the tops or lids of some NEFF models, if there is an obvious lid after trying the no power trick, take off the top and look for a stand alone reset button.
If all that fails, write me back
Will
SOURCE: Hotpoint BF1620 Integrated dishwasher not working
Lets try the following hope this works
1.- unplug the appliance, isolate it from the electric supply.
2.- Remove the kitchen unit plinth and check inside the inspection panels below the door to see if there is water in the base.
If there is, sponge it out and then try the machine again.
Was this helpful?
