SOURCE: canon printer pixma mp110
My Pixma MP110 keep on displaying "CHECK PRINTER (5800)" Please have m to solve this problem
SOURCE: my canon pixma mp830 shows error code 5010. what
The scanner lock switch may be in the locked position. Lift the cover and check the slide switch located on the top front left. If this is not the problem, you will have to have a service center look at the problem.
SOURCE: GETTING ERROR CODE E27, INK ABSORBER FULL
Canon error e27 ink absorber full/reset process
printer powered off but connected on power source , you must:
1. Press & hold stop/reset button, and then press & hold [ON/OFF] button.
2. When Green power lit, leave stop/reset button & press twice stop/reset (see orange indicator).
3. Leave On/Off button. Printer in actually service mode.
4. Press stop/reset 4 times (see orange indicator) if not blink restart above process from top.
5. After press stop/reset 4 times successful press On/Off button 3 times. printer will off.
6. Press On/Off button.
SOURCE: error on canon pixma mp 620- error 5c20- rapid
Go into maintenance tab in the printer file.( Control panel, hardware and sound, printers, your printer, select printer preferences, maintenance) Select roller cleaning and follow instructions. That might help.
SOURCE: Canon mp 270
The following tutorial on youtube.com helped me to fix this problem:
http://www.youtube.com/watch?v=RoiBaXVhS7g&feature=related
