SOURCE: Bissell Velocity Vacuum brushes stopped
The brush bearings wear out on these things. I know I replaced mine twice before buying new carpet. I've had it for 10 years,
You can order these parts on the Bissell website:
http://www.bissell.com/Products/p/CleanView+Brush/product.aspx
http://www.bissell.com/Products/ak/replacementparts/p/CVPT+II/product.aspx?%23=Detail#Detail
http://www.bissell.com/images/UserGuides/35934_804.pdf
SOURCE: Beater Bar Belt Removal from Upright Electrolux Vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=783793
Generic problem for all Vacuums
Beater bar Belt Removal from Upright Electrolux...
Posted by wrenn on Jul 14, 2008
I am trying to change the belt on an Electrolux Model 1717 Upright Vacuum and I am having difficulty disassembling the vacuum to remove the beater bar and belt.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. . Normally there are screws, clips or levers that would remove the bottom plate or if that does not work then the top cover will come off and that will expose the belt. Once that is off and the belt is exposed then cut off the old belt and then lift up the brushroll on the pulley end and install the new belt around the pulley end and re-install the brushroll. Then use a belt puller or a screwdriver with a bent right or left end to stretch the belt onto the motor pulley and then track the belt in a straight line and reverse you steps in the reinstall of the top cover or bottom plate. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
