Heating & Cooling Logo
Stan Dyer Posted on Jun 28, 2018
5amp fuse keeps blowing
Freedom 80 american standard furnace
5 Related Answers
Anonymous
  • 11896 Answers
  • Posted on Oct 28, 2009
SOURCE: I have an American Standard
EIther the valve is faulty or the ingiter is corroded or faulty. The inside of the ingniter has a shaft with a probe that keeps heated so it can ignite. It can be corroded.
Robert
  • 1036 Answers
  • Posted on Mar 02, 2011
SOURCE: How doI replace the motherboard
Hello, to replace the intergrated control board on your furnace you need to turn off main power to your furnace, then label the wires so you will know where they go on the new board. Then just take the old board to a hvac supply store and they will give you a replacement and just connect the wires to it and turn on Furnace.
Anonymous
  • 683 Answers
  • Posted on Mar 10, 2011
SOURCE: I changed the furnace filter
does anything happen, i door that you removed might have a kill switch on it so if the door comes off or is not installed right the furnace wont light, let me know and maybe i can help. wally
Robert
  • 1036 Answers
  • Posted on Aug 28, 2011
SOURCE: I have a American Standard
Hello, The only time pvc is allowed is if the Furnace is 90% or greater in effiecency, the combustion gases are cooler due to the fact that two heat exvhangers are used. One pipe will be you air intake and the other the exhaust and they can be routed through the roof or sidewall. If the Furnace is 80% then you must use double wall vent pipe and have it connected to either a liner in a chimney or routed through a roof but pvc can not be used.
Anonymous
  • 3 Answers
  • Posted on Jul 19, 2013
SOURCE: UNIT: American
What or why is there a red blinking light on front of the unit
1helpful
2answers
American Standard Freedom 80 single stage fires up... runs and blows heat for a few minutes then shuts off but then 5 minutes later it repeats the cycle. Any ideas? I have replaced the filter.
A 5 min run time tells me that it is overheating. Probably a dirty evaporator coil, or a loss of airflow due to blower issues. Or even a high temp safety that is opening prematurely? Tstat is calling for heat so its doing its job. It could be overheating or a fault at any of the components in the furnace. 90 percent of the time its a dirty blower wheel, EV. coil, or a missing filter that's so dirty its cutting off the airflow. Hope this helps!
Error code= two red flashes, lockout/ no flame
Trane XV80 hard lockout, 2 flashes, Can't be reset - DoItYourself ...
www.doityourself.com > ... > Gas and Oil Home Heating Furnaces
Jan 10, 2013 - The only way I can get diagnostic Red LED light to reset is to switch ... a2 flash with absolutely no operation from the furnace does seem to ..... inducer gets a demand you should get a pressure switch error code 3. ... the flame sensor wire and giving the furnace a heating demand after resetting power twice. Luxaire Furnace Blowing Cold - 8 Red LED Flashes
Mar 1, 2010
Winchester furnace diagnostics
Feb 14, 2010
American Standard Freedom 80 - Cold Air - Getting Error Code 9 ...
Nov 20, 2009
York ignition lockout due to retries
Dec 29, 2008
More results from www.doityourself.com
7 Tips and Tricks to repair your Furnace DIY - YouTube
? 13:25
https://www.youtube.com/watch?v=rAtcvPqUsBA
Dec 18, 2012 - Uploaded by JRESHOW .
cause this fault. 2 RED FLASHES: This indicates that thenormally open pressure ... The furnace will lock out for one hour and then restart. 7 RED FLASHES: This fault code indicates that the flame could not be established. This no-light ... problem. Bothheating and cooling operations will be affected. Check
I have a American Standard furnace Freedom 80 Mod# AUD080C936H3 and am looking for a manal or can you tell me how the exauhst is done. Can I use PVC
I changed the furnace filter on my american Standard Freedom 80 filter and now my burner won't light.
1helpful
How doI replace the motherboard on a American Standard Freedom 80?
3helpful
American Standard Freedom 80 - 9 blinks - Ignition issue
I will try to help. Your furnace has to have a good ground before the igniter will work. The draft fan starts purges for a few seconds and the ignitor is supposed to come on. If not check to see if the contacts on the air switch on draft motor are closing. If you ahve changed the ignitor that is not your problem. Another possible problem is the baord that feeds the ignitor. But check the air switch first Rus. Keep in touch.
I have an American Standard Freedom 80 furnace. When I turn it on it runs and runs and then shuts down and then the cycle starts again. It runs but never ignites. I was wondering if there is anything I...
Top American Standard Heating & Cooling Experts
Steve Sweetleaf
Steve Sweetleaf
Paul Carew
Are you an American Standard Heating and Cooling Expert? Answer questions, earn points and help others
