VizioAny other voltage than the specified voltage may .... Do not locate the antenna near overhead light or power circuits, ..... the instructions that came with your mount. ...WIDE. Switch the display mode. MUTE. Turn the audio off or on. BACK ..... Zoom. Normal. Note: Aspect ratio settings may vary by Input source. HDMI-1. HDMI- ...
setting and this is the setting in which power savings will be .... electric shock, do not perform any servicing other than ... connected to the TV, make sure that the antenna or cable system .... Locking and Unlocking the Custom Picture Modes ..... ...... .....BACK. Go to the previous on-screen menu. MUTE. Turn the audio off or on.Missing: freezes
Consult your TV's owner manual and enter "set up mode" to switch the RF or Antenna input from: CATV / Cable to: Antenna / Off Air. Then, allow the TV to scan VHF & UHF for signals strong enough to "tune in". You may need to upgrade your antenna in order to collect enough signal to display video properly. Make sure that your TV has a digital tuner (ATSC) as the old analog tuners (NTSC) have no signal to tune since broadcasters were forced to digital transmitters by the FCC years ago.
Use the site linked below to help you select an antenna that will allow you to receive all signals possible at your location - without buying more antenna than you need.
Antenna?? If you connected an antenna to the TV, you can only picking up radio waves. In the TV's menu options you should have a connection selection to choose from "Cable" or "Air". With an antenna, Air needs to be selected. Go through your "Input" selector from tv remote and select "TV" which is always the first selection. If this does not help, let us know exactly what is connected to the tv whether it be a COAX cable alone, a coax connected to an antenna, or if you have rabbit ears connected.
The manual for this AP states "If both Radio 1 and Radio 2 are set to the IEEE 802.11b/g mode, Radio 2 must be configured to an external antenna." 802.11a mode is only supported on Radio 2 per the documentation.
Ah, common problem.
You hooked up the remote turn on wire for the amp to the power antenna wire (solid blue). Hook up the remote turn on wire for the amp to the blue wire with white stripe.
The power antenna only provides power when the deck is in tuner mode for the power antenna to be extended, intuitively, and cuts power in any other mode, because certainly it's only needed for AM/FM reception.
You will have to use your remote control and go into the menu. In the menu you will see several options . One will be auto tuning. Go to auto tune or tuning channels. Good Luck
