Do you mean the GE DECT 6.0 30524 corded/cordless phone? For this landline telephone, you can switch a call from one handset to another (or the base) by using the Intercom feature. Press del/int on the handset or Int on the base and choose a handset number (use the CID +/ phonebook -) buttons (if multiple handsets are registered) or select base from the handset. Press Menu/OK to page the other handset or base. Once that device answers the incoming Intercom call, press and hold Del/Int or Int to create a conference call (both handsets or handset and base listening). Press Del/Int or Int to switch from the Intercom call back to the call on hold. Hang up on the first handset if the person on the second handset will continue to speak to the original caller alone. See pages 24-25 of the manual to see the directions. The direct link to the manual is currently https://www.101phones.com/pdf/ge/30524-user-guide-english-f.pdf .
For any landline phone, to forward a call to another phone number, you need to subscribe to a forwarding option with your telephone company. Check their information for initiating call forwarding.
If you have a different 30524 phone, please add a comment with the manufacturer.
I hope this helps.
SOURCE: GE MODEL 28112 DECT 6.0 CORDLESS PHONE
I contacted GE today and they told me how to get the caller ID to work on the additional handsets. You must follow these steps in the exact order given.
#1 - unplug the base phone
#2 - unplug the telephone line from the base phone
#3 - remove the battery packs from the phones
#4 - wait 10 minutes.
reverse the order when assembling. Put battery packs in phones, put the telephone line back in the base phone and lastly plug all phones back in. It takes about another 10 minutes after that before all phones start recognizing caller ID but it now works fine.
SOURCE: GE DECT 6.0 GHZ cordless fone (model 28111) don't ring
There is a Do Not Disturb button on the base unit. Press it to turn the feature on and off.
SOURCE: Lost manual for the GE DECT 6.0 Cordless Digital Phone # 28115FE1
http://www.home-electronics.net/ge/pc/IB/28115FE1_IB.pdf
GE phones are distributed by Thomson Electronics...the manuals are available at:
www.hom-electronics.net
SOURCE: I LOST MY INSTRUCTION BOOK FOR VTECH 6.O DECT
Vtech DECT 6.0 Dual Handset Cordless 6041 Phone If you click on the above it will take you through to the manual, hope i`ve helped
SOURCE: UNIDEN DECT 6.0
DECT 6.0 is not a model number, it's the generic name for the cordless phone technology in use. So I can't give you a more specific link than this one, which takes you to Uniden's download page for manuals. Pick your model from the list, and the manual will explain the steps you'll need to follow. Your phone's model number is on a sticker normally found on the rear or bottom of the base unit.
Testimonial: "thank you very mucy "
