Fossil JR8096 - Display Not Working
The Fossil big tic watch - model no. JR8096 has an analog dial with the seconds in a digital display at the back of the watch face. the display is no longer working, yet the watch is still showing the correct time. This to me indicates that the battery is still working, but the digital display is no longer working. I changed one battery, but are there 2 and if so, where is the other one??
your watch has two batteries inside, the small battery is the one that had to be replaced. it is under the big battery, the small battery makes the minute and hour hand move while the big battery makes the seconds flashing. i hope that i had been helped you.
(click on this link to go there) and you will see some instructions for various big tic watches and you can select the one that suits yours.
The only one that I could find that had a single button above the winder used it to cahnge the colour. Pressing this button for 2 seconds will change the colour to "alternating" and the same again will produce a fixed colour. Perhaps this will make the change of display you need.
Often with watches, you need to use a pair of tweezers to short the battery case to the chassis ((often marked "ac"). This seems to be a re-set function, although I have never found an explanation for the need to do this.
If all else fails, look up their contact details and speak to them about your problem.
The big tic has two batteries. The battery for the display may need to be changed and the circuit reset. You can then hold the display button down for 2.5 seconds to cycle through the display function.
The watch is scrolling through the seconds, and is not something that needs to be set. If there is a bottom it is only there to change the way the seconds are scrolling? There are many different types of these, but most are just standard seconds.
