I gave it a good clean noticed o ring just below fan was baggy put it back together new gas charged battery can hear fan so spark when apart stillwont fire worked intermitant before cleaning thought it was just gas can anyone help please
Sounds like its losing presure when fireing it could be the next oring if its the rubber one replace if its the metal one take them out and clean the grove they sit in and make sure u space them, meaning the gap in the rings should be set 180 deg apart. this should work if u r getting a spark when the gun is apart. the cable could be making a bad contact at the spark unit and when u r checking this make sure its getting a good contact at the spark plug as well hope this helps u.
Testimonial: "thanks, this was helpful. later found out that the ignition wires were chaved behind the trigger, but got new problem now the firing pin is sticking."
Here is a tip that I wrote
about the Paslode nailers and the problems that can come up
with them.
I also have a link to the Paslode manuals
which contain Paslode cleaning and troubleshooting guides.
If
you need parts for your Paslode, there also is a link for a
site that sells the Paslode nailer parts.
Paslode
Cordless Nailer Problems
heatman101
-]0]0-
with them.
If
Paslode
heatman101
0-0-
