Turns on to white screen nothing works or loads tried refresh/esc/ power +
The Acer Chromebook may boot to a white screen with the Chrome logo due to a recent update. At this state, the Chromebook downloads and installs the update, and then boots normally within 30-40 minutes.
If there is no updating process going on and the Chromebook boots to a white screen, the following steps should help you resolve the issue. Keep a 4 GB USB flash drive and a computer connected to the internet ready.
Hope the above steps help you resolve the issue. For instant support Call Our Toll-Free 1-866-293-9220
SOURCE: acer not work
Acer Aspire One BIOS Recovery
The AA1 has a built-in BIOS recovery routine, making it possible to
flash the BIOS even if the system doesn't boot anymore. It's only meant
for emergencies and may void your warranty, so use at your own risk.
Follow every step carefully!
First format an USB stick with FAT.
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that's important. Do not remove the USB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected.
Press Fn+Esc, keep it pressed and press the power button to turn the
AA1 on. Release Fn+Esc after a few seconds, the power button will be
blinking. Press the power button once. The AA1 will now initiate the
BIOS flash, do not interrupt it under any circumstances. After a while
the power button will stop blinking, and the AA1 will reboot shortly
after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
If for some reason you made a mistake during the procedure and it
doesn't reboot by itself wait 5 minutes before turning it off, just to
be safe that it isn't still flashing the BIOS.
Download WIN98BOOT.ZIP and HPUSBFORMATTER from the internet normal bootable like a diskette won't work with a usb stick
I had mine 2 months it's a common problem with the notebook.
The onely thing that you have to do is download these programs with someone with a internet connection.
Good luck
SOURCE: facebook Texas Holdem Poker decied to load upto
Uninstall the Adobe Flash player and reinstall it and then see wether its work or Not
SOURCE: Facebook pages dont load but get white screen -must hit Refresh
I want open facebook in pakistan how can i open?
SOURCE: Blank Screen appears when trying to install Google Chrome
there may be some error, restore ur pc to early point and fix registry errors(reginout), and then install it, and don't install any ad on
