SOURCE: Orbit sprinkler system
Have you programmed the new one with all the info for date and time? Did you set the zones for the days you want and watering times?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: hardwire the orbit outdoor sprinkler timer
Reset the timer? This will sometimes resolve many problems.
Are you sure the conduit has 120Volt? Is the timer connected to single breaker?
Or is circuit 240V? Timer connected to double breaker.
http://waterheatertimer.org/images/Inside-Main-Breaker-Box-8-8.jpg
What do you mean green wire to negative?
What else is on the conduit circuit?
Motors, fluorescent lights, and other electronics can interfere with electronic timers.
Run extension cord to timer from another electrical source and see if problem continues.
Re-post question with model number so timer-electricity expert can read the troubleshoot section of manual.
Copy following links for Orbit manuals:
http://www.orbitonline.com/support/guides/Manualsearch3.cfm?Brand=02&Type=Timers
http://waterheatertimer.org/pdf/Rona-91026-water-timer.pdf
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: Model# 57874
Copy following links to identify timer manual and general wiring illustration:
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
http://waterheatertimer.org/images/orbit-connections.jpg
Do not connect voltage directly to COM and Pump terminals... these terminals have their own 24Volt AC output when timer turns ON. When timer turns on, the 24V flows to Relay. This action will cause electro-magnet to pull two points together, and that will turn on the pump.
Same with the sensor terminals. Do not connect power to rain sensor terminals. The rain sensor plugs into outlet, and produces it's own 24V ac output. So when rain sensor activates, this cuts power to timer, and then timer will automatically bypass the watering schedule until rain sensor again resumes power output to timer.
Gene
