SOURCE: Alpine CDA-9856 not receiving XM radio
there should be a reset on the xm box itself if not the alpine has one on the face its a small button the size of a pen tip on the face or behind the face plate..this should do it
SOURCE: 2007 Toyota Sequoia Dashboard Access to Radio console FM Antenna
Pull off the 3 knobs for the heat controls. You will see a screw under the center knob. Remove it. Look to see if there are any screws near the vent grilles, remove them, if they are there. The whole center fascia then pulls out towards you. Remove the 4 bolts, and the radio is out. Easy.
SOURCE: xm radio
We had the same problem with our 2007 sonata, it is actually hapening again now. We took it to the dealer the fist time and they had to repace the xm unit (under car somewhere) apparently when it rains really hard the unit gets wet. I guess we have to take ours back again, it started acting up again after a recent rain.
SOURCE: I have an 07 Harley ultra classic. Radio had am,
the only option you have is to either take the unit out yourself, or have a harley dealer take it out and send it for repair...there is only one company in the world that services those systems, and they only take repairs in directly from Harley dealships
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
SOURCE: sirius/xm activation
Typical, they wont recognize sirius and xm on the same account. tyou need to close the old account and open a new account on the new brand head and start from square one. Also - they wont give multi head discounts if you have a mix of siruis branded heads and xm branded heads - each brand needs its own account and own e-mail address. They **** in this regard. Good luck, ive decided between this backwards book keeping and aneed to keep resetting my Sirius head periodicaly that neither is worth the aggrivation so I cancelled all of them.
Your Radio ID can be displayed by tuning your radio to channel 0. (That's one channel down from the XM Preview.) Make sure to check your ID code carefully. Please note that the following letters are not used: I,O, S, and F.
Call the activation hotline to activate your service
