Question about Generac Electrical Supplies
Generac standby generator wont cranks but wont kick over. control panel low battery & over speed/no RPM red lights flashing. all others solid. do I just need a new battery
    Sergeant:
  • 290 Answers
If you need to have a new diesel generator set in future, maybe you can contact sales@dieselgeneratortech.com. They are a manufacturer of diesel generator set for more than 43 years.
Posted on Nov 05, 2019
6ya staff
SOURCE:
Anonymous
  • 30 Answers
SOURCE: my standby generator is just cranking but wont turn all the way
If it was installed only five months ago, it should still be under warranty. Call Home Depot and have them send out a repair person.
Posted on Jul 01, 2009
Anonymous
  • 384 Answers
SOURCE: 10kw Generac Guardian not cranking, shows rpm sense loss
Sounds like Generator mode switch should be "ON".
Posted on Sep 08, 2009
ftw1952
frank thomas wilson
  • 10319 Answers
SOURCE: It is a Guardian-Generac Generator Model 0052410.
My cousin has one of these models and the same thing happened to his. It was the natural gas regulator valve that went out. He could hear the clicking noise which is the spark ignitor trying to ignite the gas pilot light. After replacing the gas regulator the unit work fine as ever
Posted on Nov 02, 2010
Ryan
  • 26 Answers
SOURCE: Generac Model 5525-1 20kw air
2 bolts on top of the front panel. Take them out and then just puul up and it come off. you can then easily remove the battery but make sure the leads dont touch as they still have charger power running through them.
Posted on May 09, 2011
Scott Alcott
  • 22 Answers
SOURCE: my rpm sens light is
you may have to reset it, its probably shut its self down, on safeties. and wont restart till you clear it..
Posted on Aug 14, 2011
Why does it crank and almost start on 1st try?
Generac Generator Troubleshooting - YouTube
? 1:39
https://www.youtube.com/watch?v=AKN2dc59cxY
Dec 20, 2013 - Uploaded by Appliance Princess
I want to learn about Generac generator troubleshooting. ... I have a 16 kW propane fueled standby air-cooled generator. ... I have a brand new generac 20K guardian Evolution and the first time my power went out my generac ...
Generac Power Systems - ConsumerAffairs.com
www.consumeraffairs.com > Homeowners > Utilities
Rating: 1.3 - ‎26 votes
Hey, Generac, make a change and start making generators that work, don't cost .....Standby generators are not supposed to be used as a primary power source ... and three months ago, I spent $4,000 to have a Guardian generator installed at ...
Generac standby generator - Propane - wont start?? - DoItYourself ...
www.doityourself.com/.../487838-generac-standby-generator-propane-w...
Feb 4, 2013 - I have a Generac 4LM41A standby generator that I need help introubleshooting and repairing. It is about 12 years old and hasn't been used ...
141 GENERAC complaints and reviews @ P'ed Consumer
Dec 12, 2015 | Generac GUARDIAN Standby Generator 10 kW/9...
WHAT DOES SENSE LOSS MEAN
RPM Sense loss means that the generator controller hasn't received a valid signal from the ignition coils for 3 seconds of attempting to start. Probably a dead or low battery or bad ignition coil. Replace the battery and try again. Call dealer if problem persist.
Aug 20, 2015 | Generac Power Systems Centurion by 16000...
Over crank
Over crank is just that, cranking and cranking for a timed period without a run signal. Make sure the fuel solenoid is opening and you have the correct gas pressure. Too much pressure can stop it opening. Then check you have a spark at the plugs, this will eliminate ignition, and you can re-focus on the fuel system. You didn't say it was LP or Nat gas
Oct 06, 2013 | Generac Power Systems Generac 5518 8 Kw...
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
My rpm sens light is flashing on my anunciator panel generator will not crank
Aug 13, 2011 | Generac Guardian RTSE200A3 200 Amp...
I have a Generac Guardian 20kw air cooled standby generator. I recently replaced the battery charger as the battery went dead a few times over the last several months. Upon replacing the charger, I now...
The battery could be bad. Try to measure the battery voltage when you try to start. If the battery is bad then the voltage will drop quite low when the battery is loaded with trying to start the set. If you can borrow a similar battery you could just try with it.
Oct 21, 2017 | Generac Guardian Model 5784 20 Kw...
Generac 43903 standby Generator overspeed indicator on starting
I have a generator that did the same thing. It would start and then stop within a few seconds. The more expensive generators have an oil level safety switch to prevent the engine from burning up. There is usually a wire connecting to the switch on the outside of the engine near the oil fill hole. Remove this wire and try to start the generator. If it runs without a problem then it is the switch. You need to remove the switch and take it apart carefully and clean it. There is a small float inside the assembly. When the oil runs low the float allows the switch to short to ground which kills the spark to the spark plug. Hope that helps.
Bob Janelli
I’m happy to help further over the phone at https://www.6ya.com/expert/bob_62dfa2f81bb55288
Oct 01, 2009 | Generac 13,000 Watt / 13,000 Watt Home...
Start runs shutsdown
Typically caused by the fuel line (LP or Natural Gas) having a lot of air in it. Was your generator just installed, or was there any work done to the gas line of the building / generator? Consult local gas contractor / propane dealer / gas company for assistance in purging the fuel line.
A low battery can also cause this as well as the generator is not able to come up to starting speed quick enough. Try placing a stand alone battery charger on the generator and charge the battery. Also check the air filter as well.
OverCrank condition occurs when generator tries to start itself, or be manually started, and the starter spends too much time turning.
This can also indicate failure of the control board. This will need the expertise of generac technician. Call 1-888-GENERAC (1-888-436-3722)
M-F 7am-6pm Central
Mar 29, 2009 | Generac 13,000 Watt / 13,000 Watt Home...
Electrical Supplies Logo
567 people viewed this question
Top Generac Electrical Supplies Experts
Sheldon Dedek
Bob Janelli
Level 1 Expert
JOHN LAPIER
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
