I factory reset due to a suggestion on how to fix the tv from powering off and on. Now it is stuck/frozen at step 3 of the set up process and keeps powering on and off. I can't get it to stop unless I unplug the tv. Unplugging and holding down the power button for 20+ seconds then plugging back in automatically gets the tv turning back on and going to the frozen step 3 screen and rebooting after several seconds. This repeats endlessly while plugged in...
SOURCE: green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
SOURCE: reset power error/hp 5610 all in one
when I dial from the phone fax will not be send and error will be come on the screen. What can i do for it.
SOURCE: WS-55909 Mitsubishi Big Screen TV timer keeps blinking
it must be recording soething have u got IQ?
SOURCE: My Magnavox plasma screen tv, model number:
You either have a cold solder joint in your horizontal deflection circuits or your or in your horizontal output circuit. please be careful due to the fly-back transformer still holds power even unplugged until you discharge it.( ground it out). Hope this helps.
