Question about Technics Audio Players & Recorders
I have a Technics SA DA 10 Surround sound receiver, it’s almost 20 years old but it still produces a lovely sound, at the moment I have notice the backlight surrounding the volume control is inoperative and when adjusting the volume with my remote, it will lower the volume but not raise it. Any tips would be gratefully received
4 Suggested Answers
Anonymous
SOURCE:
Jaime Hernandez
  • 2337 Answers
SOURCE: Technics SA-GX5OO Receiver
The noise you hear when increasing or decreasing the volume control is due to dust particles inside the potentiometer, you should use a contact cleaner to get rid of the noise by spraying it inside the volume control. Radio Shack should have the contact cleaner or you can google it.
The other failure could be some dry solder joints around components that overheat such as the amplifier IC or transistors, high power resistors, etc.
Posted on Oct 17, 2008
ABRsvcs
  • 4234 Answers
SOURCE: Technics SA-DX950 surround sound problems
The most likely culprit here is the output protection relay. The contacts are a little corroded and the higher volume "jumps the gap" temporarily "cleaning" the contacts. The relay should be changed. I don't have the manual with me, but the following relays are in the unit. One of them is the speaker relay:
Part # Cost
RSY0054-C $12.63
RSY0040M-0 $ 5.89
K6B2AHA00014 $ 8.14
Dan
Posted on Nov 12, 2008
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: I have an old Technics
Reliance on the remote instead of walking across the room to touch the unit will not solve anything. On many receivers, Muting is cancelled if the volume knob is turned to a louder level. Try that.
There's a used original remote for $12 delivered on eBay right now.
http://cgi.ebay.com/Technics-RAK-SA301P-Audio-Remote-Tuner-TV-VCR-CD-/230644267386?pt=LH_DefaultDomain_0&hash=item35b378397a
Posted on Jul 09, 2011
No sound
the service manual http://www.hifiengine.com/hfe_downloads/index.php?technics/technics_sa-500_service.pdf
Jul 27, 2014 | Technics SA-EX500 Receiver
Technics sa gx500
I suppose you did not forget to engage either 'A' or 'B' speaker selectors?
May 17, 2014 | Audio Players & Recorders
No surround Technics SA-AX530
There is likely separate gain controls for your surround channels on this receiver and they are probably set at -10dB. Enter the setup menu labled "level" and increase the amount for each channel equally.
Jun 18, 2009 | Technics SA-AX530 Receiver
Center speaker is dead or what it can be on my Technics SA-dx930.
More than like, the center channel is turned off on your receiver. Please see page 16 of the manual, which is located here:
http://service.us.panasonic.com/OPERMANPDF/SADX930.PDF
The manual says to do this:
Turn on the receiver.
Press Speaker A and B button at the same time.
The word Setting appears then changes to Front
Press A to select Center
Press B to choose Large, Small or None for your center speaker.
After choosing Large or Small, press A again till you see Complete on the screen.
If this helps, please rate my response.
Mar 26, 2009 | Technics SA-DX930 Receiver
Surround sound very quiet - technics amp receiver
darn, that was one of the best receivers ever built for the money! all the new receivers these days have 7.1. i would rather have more power in only 5 channels. puppy **** and electronics just don't mix do they? here is the link to get a new one if you like: http://www.google.com/products/catalog?q=SA-DX940&oe=utf-8&hl=en&cid=9395541207809312385&sa=title#ps-sellers
Feb 28, 2009 | Technics SA-DX940
Can't get Surround Sound with Movie
hiya
do you get full 5.1 when watching a movie from the dvd player...........??
as when u watch tv the reciever must be set to pro logic to enable 5.1 upmix as its only a stereo feed....
Dec 15, 2008 | Technics SA-DX1050 Receiver
Technics receiver shuting down
check fuse on the inside of the stereo.
Nov 25, 2008 | Technics SA-DX930 Receiver
Technics surround sound system
Use whatever TV sound output conforms to your receiver's input. If an optical or coaxial digital sound output is available, that is the way to get 5.1 surround sound through the SA-DX1050. But you have to assign the correct input (COAX, OPT1 or OPT2) to the selector (TV, DVD, CD). See pp 12-13 of the operationg instructions for D-Input instructions. If you don't have the manual you can download it at Panasonic.com.
Dec 29, 2007 | Technics SA-DX1050 Receiver
I hooked two Receivers up in series a Technics SA-DX930 and a different kind I'm not sure wut kind. They worked great for a while, but when they got turned up a little louder they both quit puting out...
you blew your power amp board, you cannot hook them in series due to impediance matching and improper input levels, cheaper to replace reciever than the board
Apr 30, 2007 | Technics SA-DX930 Receiver
54 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
