For all those who lost their Garmin manuals or have any problems with their Garmin Heart Rate Monitor watches. Follow this link, fill in the details and download manual. Tech support available as well on this site.
http://www8.garmin.com/support/userManual.jsp
Here is a link to the instructions on how to set the time on your talking watch. It says that it is a one button operation and easy to do. Good luck! http://www.assistech.com/tw-avalon1-usermanual.pdf
The Activa web site has no offering for instructions but it says that they are part of the Invicta group. You could try the instructions on the Invicta web site.
To obtain these go to "Invicta.com", put the cursor over "collections" and click on "instruction manual".
On the next page click on the link below the Invicta logo and a set of instrucitons appear.
This set is rather a long one that covers all the watches that Invicta make, so you may have to search for a while to find one that looks like yours.
Keep in mind that I dont have the watch in my hand... :-)
If this is an authentic Breitling...
You should have 2 buttons on the right with the crown between them. The crown screws down so you need to unscrew it before you attempt to set! Once unscrewed with gentle pressure pull the crown out. There should be 2 clicks, pull to 2nd click or furthest distance from case. That should be the time setting mode. Turn clockwise until the date changes then set your time. To change the date push back to the 1st click and that should be the date set mode. One direction will be for day and the opposite will be date. I believe that if you pull the crown back to 2nd click and push your buttons that should change the subdials for chrono. You might need to push both buttons at the same time.
Ive set Breitlings before but they arent a common watch we see. Most people dont use the Chrono so if the directions dont work for setting those then I wouldnt worry too much about it! Not many people are going to notice those. :-) Also be so very careful if its a real Breitling as they are a very expensive to fix! :-)
***DONT FORGET TO SCREW THE CROWN BACK DOWN OR YOU WILL GET WATER INSIDE THE WATCH!***
