Go to VideoHelp, the forum, and search for the hack for your model. If you are lucky you can find a detailed hack there. If not, you probably have to play region-locked DVD on PC with a region-free player program, or rip it to MP4.
How to Rip and Convert Blu ray to MP4 with Blu ray to MP4 Converter Best Blu ray DVD Region Free Software
Hello, Michael -
Without knowing the model of your Sylvania DVD player, it is difficult to provide you with specific directions on what you can try. Also, it would help in knowing what region your DVD is currently set to.
First, I suggest you read this article:
http://www.wisebread.com/make-your-dvd-player-region-free-in-seconds
Then, this is the link to the website VideoHelp.com mentioned in the article:
https://www.videohelp.com/
Then, you will want to click or tap on the link for DVD Hacks at the top of the window.
After that, you are on your own since I do not know the model number of your Sylvania DVD player.
Note: If you wish to post a question on VideoHelp.com, you will need to register - free - through the home page (upper right corner.)
Best wishes.
SOURCE: unlock code to unlock dvd player to play dvds from all regions
0082 0015 0089 0004 00F2 0033 0017 0010 0091 0013
make sure you have the disc draw open and enter the above code via your remote.
let me know if it works
SOURCE: Region Code Error for Philips DVP3256
hi
you can try this
>Go to Setup.
>Select Preference Page.
>Press 1, 3, 8, 9, 3, 1 on the Philips DVP3986 DVD Player remote.
>Press the up/down key to select "0" which makes it region free.
>Press ok and exit setup.
riz.
SOURCE: Region code 4 on Samsung DVD-VR355 player/recorder
I live in Australia and have two Samsung DVD/VCR player recorders, DVD-VR375 and DVD-VR355. I could only play Region 4 DVDs until I pressed DVD, with no DVD in the units, pressed Menu then 76884, then 9, inserted a Region 1 DVd and it played in both units.
Christina Weate
SOURCE: changing region code
you can change the region code with updates but its risky cos once you upload the update for the region code it may not let you play the other region coded games
SOURCE: unlock region codes
Hi, Please get the code here :
www.dvdexploder.com/
www.download-info.com/dvd/index_new.htm
www.220-electronics.com/dvd/ht.htm
www.videohelp.com/dvdhacks
Jay__UNbhGvo
