Follow this link for the answer Korg Forums View topic How to guide Restoring Pa2X 800 to Known Working...
SOURCE: Hi I have a problem with RAM memory korg pa 800 in
If it says there is a RAM memory error, there is likely a bad module. If you installed these yourself, it is likely you have installed the wrong type or an incompatible configuration of the modules.
USUALLY the modules need to be identical in these synths. When upgrading, buy a complete set fot the unit and ones that are specifically guaranteed for it.
SOURCE: KORG PA 800
Many of these pedal have more than switches. Some use resistors as part of a matrix. The chances of success are only 50-50 unless you rewire the FC01 to be exactly the same as the EC5.
SOURCE: hi i im trying to
Your answer is here:http://www.korgpa.com/pa_root/en/products/pa800_soft.html Look under Utilities.
SOURCE: Hi, I have korg
Korg pa 800 = poor quality product (I have the same problem) ,pa 2x it's better.
