SOURCE: need wiring diagram for xq-1021
That's a 'classic' bit of equipment. Unfortunately, I can't find a wiring diagram online that is available for free. It sounds like you want a service manual, and there are several places online that will either sell you a reprint or email you a pdf file of the diagram.
The first that came up was Stereo Manuals, who list it, but you will need to email them for a price. Analog Alley also lists it on their site, but again, you'll need to email the owner for a price.
There are other sources online, and it looks like the manuals show up on eBay regularly, but the two sources listed above appear to have them available immediately.
SOURCE: I have a Tork 1101.
http://waterheatertimer.org/Tork-timers-and-manuals.html#1101
1) Tork 1101 has 120Volt clock motor, making this 120Volt timer.
2) 120Volt circuit has 1 black hot wire and 1 white neutral wire and 1 bare ground wire. Ground wires connect to green screw and to each other.
3) You have two cables, each cable has black, white and ground.
One cable arrives from breaker box.
One cable goes to Load (light, fan, motor, pump etc)
4) Cable arriving from breaker box:
a) Hot black connects to terminal L.
There should be a brass connector plate that connects terminals L and 1. If this plate is removed, then add a jumper wire from terminal L to terminal 1.
b) white connects to terminal X
5) Cable going to Load
a) Load black connects to terminal 2
b) Load white connects to terminal X along with other white wire.
