The handset for the Panasonic KX-TGA273S needs to be paired with a compatible Panasonic cordless phone system like the KX-TG2700. You can turn on the handset ringer by pressing Conf/Function on the handset (lower left) when it is in standby mode. Scroll through the list to Ringer setting with the appropriate arrow keys. Press the right arrow key and scroll to Ringer volume. Press the right arrow. Then press the up arrow and press the soft key for save. This sets the ringer to low. Use the up/down arrows to set the volume. Note: pressing down repeatedly sets the ringer volume to Off. Press Save and End to exit the menu.
The manual for the KX-TGA273S is available on the product page: http://shop.panasonic.com/support-only/KX-TGA273S.html . The direct link to the manual is currently ftp://ftp.panasonic.com/accessory/phone_fax/om/kx-tga273s_mul_om.pdf . The manual for the KX-TG2700 is available at ManualsLib: https://www.manualslib.com/manual/303875/Panasonic-Kx-Tg2700.html . See page 19, https://www.manualslib.com/manual/303875/Panasonic-Kx-Tg2700.html?page=19#manual .
I hope this helps.
SOURCE: phone ringer
You can download the manual for a very similar phone, the KX-TG2302 at http://service.us.panasonic.com/OperMan/findmanual.aspx?cat=TEL and you can figure out all the features of a KX-TG2303. The simple answer is: while you are not using the phone, press the up or down volume button and it should turn the ringer back on. To turn the ringer back off, press and hold the down volume button until you hear two beeps. You can adjust the volume while the phone is ringing. The manual will tell you how to change your ringer tones, etc.
SOURCE: ringer
1. Press Menu button
2. Press multibutton "down" repeatedly to display "settings BS", then press multibutton "right" {>}
3. Press {2} two times
4. Select the desired setting by pressing {1} for low, {2} for medium, {3} for high or {0} for off.
5. Press multibutton {>}, then press on/off button
Thats it....
Have fun
SOURCE: Panasonic cordless phone,
press menu,scroll down to ringer settings,hit select,scroll to ringer volume and hit select then press up the round button in the middle until you hear it make a "ring" sound. adjust your preferred volume and hit save.
SOURCE: my vtech cordless phone will not ring. message is ringer off. how to turn ringer on.
Does your handset have a PROG button? Press that, then press the VOL+ button until you come to RINGER VOL: OFF. Press SELECT button, then use the ^ (VOL+) key until you get the desired volume level. Press SELECT again, then OFF. You're good to go.
SOURCE: My Panasonic kx tg-2620 shows "ringer off". How do I turn it on?
To solve it, I pressed Menu then the silver down arrow to access the Ringer Settings. For some reason, I was trying to use the black buttons beside the Menu button to navigate.
Thanks anyway!
