You can buy a manual here. Probably worth buying if you're going to learn how to use your machine.
https://www.sewingpartsonline.com/necchi-sewing-machine-instruction-manuals.aspx?sort.ss_cat_sort=desc&index=our1
These videos may be helpful. Although not your specific model, but most machines thread similarly.
How to thread Necchi model 535 FA sewing machine now with captions
SOURCE: How do I thread my necchi Lydia type 544 sewing machine
Threading guide - http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Necchi_Sewing_Machine_Threading/Necchi_542_544_threading_Diagram.htm
Make sure the presser foot is up when threading any sewing machine.
SOURCE: i have a necchi sewing
if you have a snap in sewing table remove it first
at the bottom in front of the needle plate area is a bobbin case door
when you open it there is the bobbin case & also should be the feed dogs
always keep the bobbin area clean of lint or loose threads
take note of how the bobbin case is inserted in the bobbin area,, see where the thread tail is at on the bobbin case
then make sure the bobbin is wound correctly or it can cause sewing problems
reinsert the bobbin into the bobbin case the same way it's removed
I also have a necchi sewing machine, the base of your is like the base of mine, if you need a picture of inserting the bobbin,, send me a comment with your email address & I will send you a picture of the threading the bobbin case & inserting it
SOURCE: Where to find Necchi 525FA sewing machine bobbin
Your Necchi uses a generic 15 Class zig zag bobbin case. Jo-Ann Fabrics sells one for White machines that will work for under $5.
