Question about Kenmore Microwave Ovens
What does it mean when E-1 pops up my Kenmore microwave
My kenmore elite 721.66462500 has turntable that attempts to turn but it sparked and popped underneath and seems it won't turn. All else works-IS IT SAFE TO USE?? kenmore elite 721.66462500
When platter doesn't turn, food will not cook evenly. The motor must be replaced. No harm will come to the oven if you continue to use it.
Nov 05, 2017 | Kenmore Microwave Ovens
What does error E11 mean?
I think this microwave oven uses an inverter to control the power output of the magnetron. Usually the microwave will advertise this feature with a trade name like "accu-wave" or "true-power" or some similar label on the front of the microwave. Assuming that is the case here, then the E11 error means a bad inverter.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Aug 07, 2014 | Kenmore Microwave Ovens
F-9 pops up - microwave stops after 5 seconds. This is a Kenmore Elite Microwave, made in 2003. Model 721 63683300
Hello :
The F-9 error code indicates a defective control board, inverter or line voltage too high .
WARNING : A microwave is capable to give you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
good luck .
please don't forget to rate !
Apr 04, 2010 | Kenmore Microwave Ovens
How do I remove the handle on a Kenmore Smart Touch microwave?
get a butter knife and be very careful and pop the plastic ring off from the inner door and you will see the screw. if you break the plastic ring you need to replace it to help block RF
Feb 05, 2010 | Kenmore 63252 Microwave Oven
Kenmore Elite speedcook oven Model 63799. F2
f2 error means : -------
1. The oven temp has risen above 665F and the door is not locked or
2. The temp has risen above 965F with the door locked
------------- if this happens you should check: -----------
1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits
2. Check and replace oven temperature sensor if necessary
keep updated,please do accept and rate the solution.thanks.
Sep 30, 2009 | Kenmore 63792 Microwave Oven
Microwave made loud popping sound and now does not heat.
Hey,
Try this
Probably a high voltage diode popped because contaminated grease eventually built up and made a path for a high voltsge arc to occur.. To confirm,take the outer cover off the microwave and discharge the high voltage capacitor by shorting its terminals. Then pull the plug off the magnetron side and place it near the magnetron socket. Now turn the microwave on and push the connector on the magnetron with a chopstick or a long insulated screwdriver. If no arc when you do this this confirms a bad diode.
please rate my suggestion..
Apr 13, 2009 | Kenmore 62702 Microwave Oven
Kenmore over the stove microwave will not heat 1996
YOUR MAGNETRON IS MOST LIKELY BAD. THIS IS THE UNIT THAT CREATES THE MICROWAVES.
Apr 11, 2009 | Microwave Ovens
Pop pop Kenmore hood microwave 665.60652 - year 2002
hmmmm, i wonder if you have a gear or something similiar to this going out. (turn tables)
If not, something tells me you have a component that is arching inside of your micrwave. I would call someone to double check to make sure it is ok.
You will be surprised at how many people wait until it is too late to service their units, when it goes out, it is gone.
good luck
May 25, 2008 | Kenmore 62702 Microwave Oven
Microwave no heat
The "HUMM" indicates a breakdown in the High Voltage Side. The loud "POP" was the breakdown. You have only four Components in the High Voltage side.
1. High Voltage Transformer. You can eliminate this as the problem. Why? If it was the problem it would have blown the line fuse, and would have given off a burned transformer smell.
2. High Voltage Diode. Usually will Burn or Pop when shorted, but will then OPEN the Circuit and there is no "HUMM".
3. High Voltage Capacitor.This is the Silver Can with the two terminals on top. It can SHORT internaly between the plates (the two terminals) and give the "HUMM".
4. Magnetron. This is my number one suspect. A SHORTED Magnetron.
Feb 03, 2008 | Kenmore 63652 Microwave Oven
Microwave Ovens Logo
327 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
