SOURCE: Digital Voice Recorder VN-3100PC transer from PC back to recorder
With this particular model of recorder that functionality is not possible as when the recorder is connected to the computer it is not a USB Mass Storage Device. It will only files to be downloaded to the computer not uploaded back.
SOURCE: How can I transfer files form a VN-2100PC recorder
Digital Wave Player (2.0):
http://www.olympusamerica.com/files/DigitalWavePlayer.zip
After unzipping the file, click on the SETUP.EXE file to begin installation.
Download update: http://olympusamerica.com/files/DWPUP2EN.zip
Download update 2.1.3: http://olympusamerica.com/files/DWPUP4EN.zip
Do not have recorder connected until all software installed and then reboot computer. Once computer rebooted then connect the recorder.
SOURCE: CANNOT TRANSFER AUDIO FILES FROM WS-100 OLYMPUS
I wrote this for the Olympus VN-3100PC although it may work with this device as well.
Try this:
This problem can typically be solved by unplugging the device from
your computer's USB port and plugging it in to another USB port on the
same computer.
Also be sure you have Olympus Digital Wave Player installed and open with your Transfer Options set to Auto Transfer. To do this, follow the steps below:
Open Digital Wave Player > select Transfer from the menu > select Transfer Options > under Auto Transfer, check the box which reads "Transfer all audio files after detecting Recorder."
SOURCE: i can't transfer my files from recorder to pc
same computer.
