Just installed cover. Pulled it with pull strop and all fit nicely. Turned release knob 90 degrees, nut cover won't budge. What should I do
The best solution you'll get from books at www.reliable-store.com
These are books containing info on repair, service, troubleshooting, parts info, assembling dissemble, removal, error/fault codes, wiring diagrams and everything on any vehicles cars, atv, trucks. forklifts, boats, excavators etc
SOURCE: Hood release won't open hood, can't open my hood
don't know what vehicle but it's possible if you look through the grill you may be able to see the cable and using a screwdriver pry the mechanism to open it be carefull if it's a plastic gill you could break it
SOURCE: emergency break cable broke on 2004 silverado
I had the same problem on my 2003. Open the driver door all the way. Get on your knees just outside the door. Follow the plastic tub that holds the parking brake release cable inside the truck. Start from the release lever and follow to the end of the tube. There will be a metal lever that the cable was attached to before it broke. You have to pull that lever with your hand to release the parking brake. Very Important!!!...Hold the parking brake activation pedal with your other hand when you release the brake. Let the pedal out slowly when you pull the metal release lever. The pedal will come back very fast and you could injure yourself if you are not careful. Good luck!
SOURCE: Glove compartment stuck
I just opened my friend's stuck Toyota Corolla glove compartment by
pushing in on the bottom right front with my foot while pulling the latch and giggling it. The latch turned out to be broken. Good luck.
SOURCE: 89'S10 Blazer tailgate won't open
Thats what you will need to do is to remove the interior gate panel so you can release the latch. It will come off although a bit difficult with the gate closed, with a little care you can do it without breaking anything. It sounds like possibly a linkage retainer clip broke.
Try pushing in on the gate while turning the release handle in case the latch is in a bind if that dont work remove the panel
SOURCE: Stuck hood latch on 1996 chrysler concorde- Possible broken cable
take off the left front wheel and fender well. slice off the hood cable insulation get a hook too pull the wire have a buddy pull up on the hood while doing this. Should pop open then hope this helps u out.
