SOURCE: electric oven too hot
difficult to see what you have done here! can you come back with some info: do you have an earth trip fitted in your consumer unit? how many wires are fitted to the element? did you touch any other wiring except those connected to the element?
SOURCE: MAJIC CHEF DOUBLE OVEN NOT WORKING
I just had a model 976-4CX put in...I have no manual...I'm trying to find one. I thought I had a problem with the element, dial or thermostat. The bottom worked, but the top stopped working. There are 2 timers with dials next to the clock labeled Start and Stop, and Push for Manual. Come to find out my problem was solved by adjusting the Start and Stop dials and/or pushing in for manual!?!
If I had a manual I'd know how these timers worked.
SOURCE: zanussi zbf260x built-in oven keeps tripping out
Probably due to a fault on the oven heating element. Check continuity and earth with a multimeter if you can but it's odds on you will need a new heating element.
SOURCE: Oven tripping
Was the oven tripping the the fuse before the element was replaced,also did you take the oven out to do element because the element can be done with cooker in place it may be that you pulled out the connections block at rear of unit and it is touching body.If tripping before replacement the fault could be any where on the oven.You will have to check it through.
