SOURCE: whirlpool duet ht wouldn't start
remove the lower front panel,3 screws,side up and off,there is a tech sheet inside on the panel that should help you ,let me know what you find-mike
SOURCE: push start button on control panel - machine does not start
only 2 things can cause this.
1 the control is set to lock out mode. just hold the lock button for 5 seconds and it should go back to normal mode.
or 2 the controls user interface has an internal failure. its the part that has the switches and tells the computer what to do. either way call whirlpool and see if its still covered by their warranty.
of yeah and the 3rd thing is you have no power to unit. make sure the outlet is good by trying something else in the same outlet, like a light or hairdryer.
SOURCE: LD is on my display-nothing will clear it and washer doesnt drain
the ld code means a long drain, what you probably have is something blocking the drain pump.
you can get to the drain pump from the back of the unit and it will be the pump on the left as you face the back.
you will need to remove the hose going into the pump and be ready for water to come out. sorry but you need to check inside the hose as there will be something blocking it. like a coin or some lint or a small sock.
when you get the item out of the hose then it should work again. you do not need to reset the control. once it knows the unit is draining properly it will be ok.
SOURCE: Whirlpool HE WFW9200SQ00 is Dead
control unit dead, replace main control and possibly user interface. Sorry this is very common failure on whirlpool.
SOURCE: my Whirlpool Cabrio washer won't start when
The Start button is broken, the user interface board is not working, or the machine/motor control board is out. Perform the diagnostic test to verify all machine functions. The Start button is indeed broken if machine functions work fine during the diagnostic test.
Put the machine in standby mode by plugging it in with all indicators off, or with only the Clothes Clean or Done indicator on. Select any one button except POWER, START, and STOP then follow the steps below, using the same button.
Press/hold for 3 seconds, release for 3 seconds, press/hold for 3 seconds, release for 3 seconds then press/hold for 3 seconds and release. All indicators on the console will be lit for 5 seconds with 88 showing in the Estimated Time Remaining two-digit display to indicate that the diagnostic mode has been entered successfully. If indicators do not display as described, the press/hold and release procedure may not have been performed within the time frame necessary for successful entry. Repeat the procedure and you may use another button to ensure this was not the cause.
The program then checks for saved fault codes. Post back any saved fault code for further advice. If there are no saved fault codes, all indicators on the console will momentarily turn off, then turn back on with 88 displayed and after 5 seconds, the diagnostic test begins with C0 displayed and the lid may be opened. Press the same button used in activating the diagnostic test above to advance through automatic test steps. Allow step C1 to complete before advancing to the next steps. Post back the result fro further troubleshooting advice.
