Bought fridge in January, 2018. Recently the door alarm won't stop beeping, randomly...it goes on and then will turn off...and then on again some time later...no rhyme or reason. No water dispenser. Doors are shut tight...running out of ideas and sanity is soon to follow.
SOURCE: Samsung Refrigerator SR-608EV with water dispenser
There is another sensor in the door that senses how far open the door is. look for this and see if its disconnected or broke
SOURCE: My 1998 Volkswagen Jetta's alarm goes off
check a reputable alarm installer sound like your factory lock module is giving trouble
SOURCE: VW Beetle Alarm goes off for no apparent reason
the sensitivity on the alarm itself is too high, or there is something around the car that is interfering with the frequencies that are sent / received by the alarm itself, like other car alarms, power lines (mine actually did it when i parked under a power line) or the alarm unit itself is malfunctioning.
make sure that nothing is around to the (other cars with alarms) or look up under your dash, above your pedals (might have to take the trim plate off) and / or turn the sensitivity knob (flat-head screw driver, or just a simple protruding knob) down. make sure the battery in the remote is good too. if it stil ldoes it after this, then your remote needs to be reprogrammed.
SOURCE: Hi, i have a whirlpool american style fridge that beeps etc.
its the compresor packed up,,,if this compresor is not pumping freezer gas around the pipe work the freezer wont work sorry but a new compresor is not a cheep thing to have fitted as it will need a re-gas as well
SOURCE: Hi My Fisher & Paykel Model:
if i beeps about every 8-12 hours check defrost system and look for ice build up in freezer.
