Https://phones.brain-start.tech/block-phone-number/how-to-block-a-phone-number-on-doro-phoneeasy-612/
How to block phone number on Doro PhoneEasy 612 Phone Info
Quoting from link: "Start by going to "Contacts" and tap on the contact you want to block. Then, press the menu key at the top left of your Doro PhoneEasy 612. You will see a menu where you will select "Block Number" or "Add to Auto Reject List". The title may vary depending on the model you own."
SOURCE: blocking calls, motorola razr v3
Yes, sort of: go to Settings->Security->Enter lock code here if you've created one(otherwise ignore this step)->Limit Use->Restrict Incoming Calls
From this step, you'll have to choose to restrict incoming calls from anyone NOT in your Contacts
SOURCE: cell phones
u must install advance call management software... by using this u can make the black list of the persons 4 whom the ringing sound will not be heard but u will be getting calls just some thing like this & u can make busy tone always.....
install this & enjoy
SOURCE: how to get the messages of doro 615R+2 digital phone
down the bottom right corner , on the hash button, see the little x sign under the key, when you have listen to a message push that and it will be deleted then the next one will be heard and repeat untill you finish. hope this helps
SOURCE: blocking unwanted numbers
Normally you can so long as the caller is presenting their number through Calling Line Identification (CLI) - ie you can see the incoming number on the screen.
If you can see the number, save the number into your phonebook. Create a Group in your phonebook and put the number in it. Then normally you can automatically reject calls from a Group - either by the Group options, or by the settings under the phones Profiles.
SOURCE: how to block incomeing calls on a samsung mdl sgh
If your fone has a blacklist feature which can be found in:
Settings > Call > Blacklist..
1). Enter the international code or the plus sign..
e.g "+" or "00"-Australia,New Zealand.
2). Enter country code.
e.g "61X"-Australia, "64X"-New Zealand.
3). Enter mobile number.
Activate this feature and you should be fine.
