SOURCE: Whirlpool model WBP36800 range.
souds as if a monitor switch has gone bad on your self clean latch mechanism.its continuing to lock and unlock door because the switch that tells the control that the dorr is unlkocked has gone bad and as a result continues to rotate constantly
SOURCE: Whirlpool range problem
If you where to touch bake, does the unit turn on? Or is the keypad none responsive? I would say if the keypad is non responsive you have a bad keypad. Can you check the connection and see what happens after you unnplug the connector and reattac. Does the lights light back up? Do you have a Display? If the Display is not working could be a possible bad controller.
SOURCE: Our Whirlpool electric range shows 5 Ab
There is nothing wrong with your range. The code you are seeing on your display is actually "SAB". It means your range has been set on "Sabbath Mode" which is used by some religions to disable the stove to honor the sabbath. It will remain disabled for up 72 hours unless you turn it off. The procedures to clear this mode differ between manufacturers, so you need to refer to the operating instructions in your Owner's Manual to see how to turn this feature on/off. You cannot clear this by unplugging it, either. If you can't find your owner's manual, you can go to managemyhome.com and type in your MODEL NUMBER under the "Manuals" link. They provide owner and installation manuals that you can view or download for FREE.
If you have any questions, please let me know. I hope this helps you.
SOURCE: my troy bilt horse has serial number 544253, can
if you have a B&S engine look at the frist two numbers on the code. thats the year of the engine and more likelyof your unit, As long as the motor has'nt been replaced. I'll checked on your serial number did'nt find a model. If this is an old troy built I'll have to call tech support. also I need to know what engine 4, 4.5, 6, 7, 8, hr power, and the name of the teller. MTD now owens troy built.
SOURCE: What are the correct fuses to use?
if it operates on 240 volts then a tandem 40 amp breaker or 2 40 amp fuses will accommodate the unit fine.
