Cars & Trucks Logo
F
Fred Smith Posted on Jun 14, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is Ford approved fix for carbon buildup on 2106 F150 3.5 Ecoboost?
Rick M
Level 3:
  • Ford Master 4,148 Answers
  • Posted on Jun 14, 2018
Rick M
Ford Master
Level 3:
Answers
4148
Questions
0
Helped
1252338
Points
13941
We'll have to wait for the 2106 service bulletin. But on 2016 models, try this
Carbon buildup in Gasoline Direct Injection engines Ricks Free Auto Repair...
1 Related Answer
Mike OSullivan
  • 56 Answers
  • Posted on Feb 21, 2016
SOURCE: How do I fix my ford focus 1.0ltr ecoboost electric drivers window?
Usually it is simply the switch which is common failure, and easy to fix, but window motor is second thing to check, and of course, sometimes it is loose connector
FREE-PPV.com
Is the Ford Escape 1.6L EcoBoost knock sensor bolt torque spec the same as Ford Focus RS?
The torque should be around 12 to 18 ft/lb (16 to 24 Nm) on most engines. The settings for the Focus and the Escape are slightly different so work to about 15 ft/lb (20Nm) for both cars.
Flex plate nuts torque for 2014 1.6 l ford ecoboost?
That's not how it works. To look up a torque spec, we need the year, make, model, engine. We have no idea what model you're working on.
3.5 Ecoboost. How can I replace vacuum pump gasket?
2014 Ford F-150
3.5liter Ecoboost
ok I see it, it just unbolts. what stops you>?
o-ring seen here.
How to reset air bag control module on ford f150 ecoboost 3.5l 2013 cliff
You fix the problem. It resets itself when the trouble is fixed. You can erase the code with a scan tool, but if the problem isn't fixed it'll light up again. There is no "reset"
FREE-PPV.com
How do I Fix a PO401 code for a 1997 Ford Explorera with a 5.0 engine
po401 is insufficient air flow from EGR valve. check the vacuum hoses from egr, if ok, remove or test the egr valve itself and try to clean it out. Good-Day! It may just be sticking, from carbon buildup.
2helpful
2answers
I have the error P 2106 on my ford explorer 2005 because there is message "fail Engine safe mode"
That means the accelerator pedal is in fail safe and you will only get 35% throttle accleration you should have other accompaining codes with this 2106 and those should be done first if you have ABS codes that has to be done first,2106 can be causes by a open TAC wiring disconnect, a TPS sensor that has failed (Throttle position sensor), Here is the big concern you will need to check to see if all the module are communicating with each other, you mainly will have to go to the dealer for this concern and only thier scan too can fix it and find the problem
1helpful
Ford f-150 stalls when i turn and have the clutch pushed in. it only happens occasionally. does anyone know what this could be. is it expensive to fix
Try removing the Idle Air Control from the top of the Throttle Body and cleaning out the holes underneath. Often they become fouled with oil and carbon buildup. If that doesn't work, You may need to test and/or replace the Idle Air Control valve.
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
