SOURCE: Apex Digital TV Model: 1919. Worked fine for a
Power supply issues or shorted horizontal output transistor. Probably not worth having repaired unless you DIY....
SOURCE: Remote control code for an APEX digital converter
If that code is not listed in the little booklet that comes with the remote control then it's probably not capable or controlling the APEX converter. Most of the universal remotes can't accommodate digital converter boxes. The only possibility is doing a search for the code manually as instructed in the booklet. I suspect you won't find anything that will help you out except getting the original control from the Manufacturer or replacing the entire box and you will get a new remote control with it.
This is a problem I have run into before, the universal remotes people just don't have access to the digital converter codes. They are proprietary and vary from model to model and brand.
Zashiban
SOURCE: Need a Philips universal remote code for Apex digital tv convertr
try going to this Philips site and using their universal remote control finder tool ...
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?tmplt=ePlatform%20-%20Philips&scy=US&slg=AEN&sct=REMOTE_CONTROLS_SU1&cat=REMOTE_CONTROLS_CA1&session=20100815184715_64.252.199.203&grp=SOUND_AND_VISION_GR&ctn=SRP4004/27&mid=Link_RCCodeFinder&hlt=Link_RCCodeFinder
RCR450 have no setup codes to Apex TV. There is no RCA remote control models have set up codes for Apex brand.
SOURCE: Need 11 digit access code for apex model LD3288t, the access code text to me does not work
mak sure u have a SIM card in
