Hook is slipping and don't know where set screw is?
SOURCE: consew 226 r sewing machine
Take the bobbin out and check for dirt or broken thread in the hole.
SOURCE: How do you adjust the stitch length on Consew 226 R-1?
if it is like the other industrial machines I've used, here is the general principle:
On the machine there is a button with no label. Hold button while turning the handwheel toward you. When you feel the button depressl you can adjust the length. Hold the button in the machine and crank the hand wheel back to decrease the length of ths titch and foward to increase it. I usually put a notch on the fly wheel for my standard length with some nailpolish. Release the button and sew to test the length.
SOURCE: looking at a used consew 226 and found a new 226
Go to www.consew.com. Either send an email or call them. They're very responsive to questions.
I have a 226R-1, my second one. Both of mine were built in Japan and are/were at least 2- - 30 years old. I think current models are made in China. Serial numbers are under the bed on the front side of the bed.
SOURCE: Consew 226 breaking needles
I posted an answer to this a couple days ago. If the hook's hitting the needle you need to move it away from the needle. There's a small screw in the bottom of the machine that holds the hook mechanism in place. You need to loosen the screw and gently tap the assembly away from the needle. The hook should just pick up the looped thread as the needle bar rises. You can go to www.consew.com and download a pdf file showing the parts of the machine, also an owners manual. You have to click on the 224 machine. The manual's the same for 224, 225, 226. Or you can click on the 226R-3 - that's the same, too.
