Solution:
Step 1:
Make sure the that router is connected to your modem with an ethernet cable via the router’s internet (WAN) port.
Step 2:
Unplug the modem from its power source and make sure that it's totally turned OFF. Then re-plug the modem to the power source.
Step 3:
Unplug your router’s power supply, wait for 10 seconds and then plug it back in. This will cause the router to reestablish communication with the modem.
If you still cannot browse the web, contact your Internet Service Provider (ISP).
Solution:
Step 1:
Step 2:
Step 3:
Solution:
Step 1:
Step 2:
Step 3:
Site reference link:
https://www.belkin.com/us/support-article?articleNum=56519
SOURCE: belkin n150 F6D4230 wireless router. lose ability to
try to upgrade the firmware of the router. that will help you.
For this you will need to connect the computer to the router. Do not upgrade the firmware of the router using the wireless computer.
You will need to download the new firmware from the manufacturer's web site. Then open the router set up page and upgrade the firmware of the router.
Click here for more information about routers and network
SOURCE: Wireless connection on Belkin wireless router
click on the small two computers by your clock, check to see if it is enabled. if that doesnt work just redo it all over again.
SOURCE: I have a Belkin F6D4230-4
Do a hard reset on your router by holding in the reset button (while it is powered on) for at least 30 seconds. Release the reset button and power off the router. Hold the reset button again for 30 seconds. Then power on the router.
SOURCE: i want to take the security lock off my belkin f6d4230
Hi here is the answer for your question:
1. We need to establish a direct connection bit-win your router and your pc or laptop using the UTP cable one side of the cable must need to connected to one of the port in the back side of your router the other side to your lan port.
2. open explorer or any browser you using and type on the top search bar 192.168.2.1 this is the address of your router press enter and you will contact your router set up page.
3. after you must go to wireless security that appera in the left side of the page, after that you will able to change the password of your wireless security.
more question let me know
Techbelkin
