Starrt on 23 there is no reset
http://kitchen.manualsonline.com/manuals/mfg/samsung/dw80f600uts_1.html
SOURCE: Whirlpool Dishwasher Not Working
Change the thermal fuse in the control and door switches. The thermal fuse is designed to fail if there is a problem with the switches.
SOURCE: I have a Karcher electric power washer. The
do you mean the gfci that is normally at the end of the cord or the switch on the unit itself. if its the ground fault circuit interrupter its detecting a short to ground and protecting you from recieving a shock.must inspect inside unit for possible moisture around motor or switch i don't think its overloading
Hello Jamie Wolz - Try resetting the unit either by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. Make sure the rinse aid dispenser is filled and check that the incoming water temperature is not less than 120 F. Restart unit and select normal cycle. If it proves to be ineffective, contact a professional to move forward accurately. The dishwasher may be experiencing a wiring failure or a communication error with the control panel.
