Lands Phones Logo
VCRR Posted on Jun 11, 2018
Hi My Motorola cordless phone C1012LX .In on of the handset it says unregistered .how to fix this problem.
5 Related Answers
Anonymous
  • 4102 Answers
  • Posted on Jan 29, 2008
SOURCE: AT&T 2230 2.4 GHz Dual Handset Cordless Phone - additional phones?
Hi yes you can add additional phones to it as long as their the same frequency so that they pick up the signal from the main phone that plugs into the phone line.
Im sure you can have upto 4 handsets but just make sure theis same make and frequency
Anonymous
  • 3 Answers
  • Posted on Mar 04, 2008
SOURCE: handset says unregistered
The manual says that to register it needs to be completely powered off and then restarted. I unplugged my battery and then plugged it bacdk up.
Anonymous
  • Posted on May 30, 2008
SOURCE: GE MODEL 28112 DECT 6.0 CORDLESS PHONE
I contacted GE today and they told me how to get the caller ID to work on the additional handsets. You must follow these steps in the exact order given.
#1 - unplug the base phone
#2 - unplug the telephone line from the base phone
#3 - remove the battery packs from the phones
#4 - wait 10 minutes.
reverse the order when assembling. Put battery packs in phones, put the telephone line back in the base phone and lastly plug all phones back in. It takes about another 10 minutes after that before all phones start recognizing caller ID but it now works fine.
Anonymous
  • 3 Answers
  • Posted on Aug 09, 2008
SOURCE: Deregister lost or broken phones
Some tricks from a helpful Uniden rep:
holding down end+# keys at the same time on the phone for about 10 secs (you will hear a beep) will deregister the handset. If you have a dead handset and want to deregister it from the base, you have to reset the base. unplug the phoneline and power. hold down the "delete message" key, plug power back in. about 10 secs later, you will hear a long beep (theres a short beep upon powerup as well). At this point all handsets are deregistred and you will have to reregister them with the end+# trick. this way when #1 handset is dead, you can make a working one #1 and get the broken one fixed emotion-1.gif
BTW, this is a woot warranty, not uniden warranty. however the uniden rep gave me the number to the people who refurb (rox0rz!) these. I'll post an update when I finally get ahold of them (and the number if its actually helpful)
A
Anonymous
  • Posted on Oct 13, 2008
SOURCE: The screen on the cordless
I think you may need to change the display
1helpful
Hi I have a Cordless Uniden Dect 6.0 and also another one that sitts on a bitter base. My problem is this: the cordless with the smaller base shows the message 'Searching' and wont do anything,...
Welcome to FixYa.
Reset the units/set up by doing the following:
  • Turn OFF all the HANDSETS.
  • Remove the batteries of the HANDSETS.
  • Unplug the power source of the BASE.
  • Unplug the phone line of the BASE.
  • Let it stay that way for 30 mins.
  • Insert the battery again of the HANDSETS, make sure it is charged properly.
  • Plug back the power source of the BASE.
  • Plug back the phone line to the BASE.
  • Register any handset that is unregistered (refer to manual).
Keep me posted.
Jas247
Why is it my uniden phone indicates unregistered?
The cordless handset is not registered with a base station. Please refer to the manual for instructions on registering the handset.
Registering a new phone
how do i register my new samsung rant phone ?
1helpful
Motorola D210 Cordless Phone
hi i have problem with motorola 210 cordless phone ta base is ok but ta single handset screen shows unregister this why is not working.
Tru 9496
SOLUTION:
1. First, remove the battery cover on your unregistered TCX905 and look under the battery to confirm that you indeed purchased a TCX905 because some Uniden handsets were packaged as 905's but were not.
2. Take the fully charged unregistered 905 to the base unit TRU9496.
3. On the TRU 9496 base unit press "Menu" then select "Registration" and press OK
4. You should get the message "press the # key on the remote handset".
5. Depress the "#" key on the unregistered 905 and it should register.
1helpful
Phillips dect2152
If you bought the base and handset together they should already be registered. If not then the instruction manual is downloadable here: MANUAL
The relevant section is on page 16 - here is a copy:
4 handsets can be registered to the base station. A handset
can only be associated with 1 base station.
�� To register another handset
First enter registration mode by unplugging and
plugging back in the power adapter to the
electricity supply.
Handsets registering / unregistering ( )
�� To unregister the handset you use
enter the RC code*
�� To unregister all the handsets (except the handset you are using)
enter the RC code*
Once the menu is selected, enter the RC* code written under the base and press
to confirm.
Warning : If you wish to associate a non-Philips handset to the DECT 211 or DECT 215 base
stations, make sure that these handsets are GAP compliant otherwise they will not operate properly.
*RC code
(Registration
Code) is
written under
the base.
Warning : Once unregistered, the handset is no longer operational.
Please rate my assistance this should be a fixya!
Handset says unregistered
4helpful
Panasonic KX-TG2740 Cordless Phone - Can I reset handset registration
press function button on handset, scroll to initial setting, select by pressing right arrow, scroll to registration, select, select hs registration, follow directions on handset display, pressing mute on "new" base station, and ok on handset(plugged in). If you like, you can unregister with the "old" base unit first.
Top Motorola Lands Phones Experts
ADMIN Andrew
ADMIN Andrew
CJ Rock
CJ Rock
Are you a Motorola Lands Phone Expert? Answer questions, earn points and help others
