SOURCE: front parking/side marker lights
Replace bulb, it has 2 filaments, one is probably burned out.
SOURCE: hyundai matrix 2002 year, both
i have a hyundai matrix 2002 too and this morning as I drove in a light came on on the dash with a picture of an engine and the word 'check. What could be the problem?
SOURCE: no tail lights,marker lights (FRT. OR REAR), license plate light
i had the same problem with my 2002 Dodge Ram 1500, the front light control module is bad and its about a $250 part.
SOURCE: NUMBER PLATE LIGHTS NOT WORKING
take the bulb back out and clean inside the bulb holder, there may be some corrosion or other debris in there
SOURCE: NO LEFT SIDE TAIL ,STOP OR BLINKER REAR LEFTLIGHT
did you try to replace the bulb in the back normally when it blinks fast like that its just the bulb and its doulbe film thats why the brake and blinker dont work
The tail and marker lights and Instrument lights are on the same circuit so both will go out if the fuse for this circuit blows. If fuse continues to fail, check the tail light or marker globes, including the globes for the number plate, for a globe that may have an internal short causing the fault and replace as necessary. As you have already checked the wiring near the light fittings for any chafed wires that could be shorting to the body causing the fault, then a closer inspection of the wires inside all the light assemblies for any shorts may be needed.
It could also be that the instrument dimmer control has failed and is causing the fault. The electronic bits inside the dimmer control for these lights sometimes go faulty. Try disconnecting the connecting plug on the rear of the dimmer control and checking if fuse still blows. If fuse continues to fail, then the fault in the tail and marker lights circuit.
Remove all the tail, number plate and running light globes from the light assemblies and leave the instrument dimmer control disconnected and check if fuse still blows.
Disconnect the plug near each of the light assemblies to see if any of the individual assemblies is causing the fault. With all light assemblies disconnected and fuse continues to fail, then the fault must be in the main wiring loom some where.
If you have a Multimeter, it could be used to determine which light assembly has a fault between the lamp supply and earth connection.
The Tail lights and Instrument lights are usually on the same circuit so both will go out if the fuse for the circuit blows. Check for a blown fuse for this circuit and replace if out. If fuse continues to fail, check the tail light or side globes for a faulty globe and replace if necessary. Also check for any chafed wires that could be shorting to the body causing the fuse to blow.
