Dave Mack Posted on Jun 09, 2018
Where can I get another charging cord for my Bluetooth speaker
2answers
Need a USB cord to charge Memorex wireless blue tooth speaker
First, I'm not a Memorex tech.
* speaker product info; https://www.amazon.com/Memorex-MW212RC-Wireless-Bluetooth-Speaker/dp/B00VJYWVAS/ref=sr_1_3?ie=UTF8&qid=1531097511&sr=8-3&keywords=memorex+wireless+bluetooth+speaker&dpID=41irUx8yT6L&preST=_SX300_QL70_&dpSrc=srch
* This one has a charger (but does not show the plug type) ; https://www.youtube.com/watch?v=tWTpQGSpoVU
* Memorex-FlexBeats MWB3363 uses an odd Apple cable; https://www.bestbuy.com/site/memorex-flexbeats-mwb3363-portable-bluetooth-speaker-gunmetal-gray/5763903.p?skuId=5763903
* Apple 3.3' Lighting to USB cable; https://www.bestbuy.com/site/apple-3-3-lightning-to-usb-2-0-cable-white/6652043.p?skuId=6652043
* This model uses a wall charger and if you check the "Answered Questions" There is a hint that it also uses AA batteries. (I suspect at least 4 AA batteries for estimated 6 volts); https://www.amazon.com/Memorex-Wireless-Bluetooth-Discontinued-Manufacturer/dp/B008X1C69G
* there should be a port to plug in the AC adapter cord. Check the ID plate for the power requirements (should be 6 to 12 volts DC). Take the speaker or take a picture of the plug socket and the ID plate. Check out your local electronics shop, Home Depot, Lowe's, or Best Buy and have there sales people find you the right charging plug.
* Sorry, can't seem to find a valid Memorex Support contact other than Memorex-Amazon.com
* Check the ID label for contact numbers or web site.
Aloha, ukeboy57
My blaster mini (new) wont charge
1.Check the LED light
Generally speaking, the LED light will start blinking when you connect the charging cord and charger to your Bluetooth speaker. Like the EasyAcc Mini 2 Portable Bluetooth Speaker features a 360 degree LED light which wraps around under the top metal and indicates the charging status. If the light is broken, probably the speaker is charged for real but the light says the opposite. If this is the case, try to turn it on after 1 hour's charging, if it works fine the LED light is broken for sure. It's not completely handy to use the defected Bluetooth speaker but at least there's no other system problems encountered.
2.Switch the charging cable and adapter
It has a great chance of applying broken cable or charger when the Bluetooth speaker not charging, therefore go to switch them to identify whether they are at fault or not. If so, directly replace them to qualified ones.
3.Clean charging port
Chances are that the charging port is choked with lint, dust and dirt. A can of compressed air can blow out the offending irritants and get your USB connection back to normal. If the charging port becomes loose, do not try to fix it by yourself if you don't get any experience with the tools like pliers or tweezers. Go to ask customer service or someone with solid skills for help.
4.Update/Reset software
The dead battery issue also occurs when the software is out of date, the manufacturers regularly release the updates or upgraded drivers to solve the corresponding problems. This happens on lots of rechargeable devices out there and there is usually a fix.
After all, if still says not charging, contact the after sale customer service and get support immediately or get it replaced under warrenty.
JBL Charge 2 stopped wifi connecting to pc
Problem connecting Windows 8.1 pc to JBL Charge bluetooth speaker ...
answers.microsoft.com/.../windows/.../windows8...connecting-windows...
When I try to connect the pc through Bluetooth to the above wireless speaker ... 2) What is the model of the JBL Charge Bluetooth speaker? ..... I am already able to play music from my iPhone 5 on this speaker via Bluetooth with no problems.
Cannot connect JBL Charge Bluetooth - Networking, Internet ...
en.community.dell.com/support.../network...wireless/f/.../t/19525571
Dell
Sep 22, 2013 - 16 posts - ‎11 authors
23 Replies; 16 Subscribers; Postedover 2 years ago ... I'm trying to connect my JBL Charge Speaker bluetooth with my Dell Studio 15 laptop to listen .... I am having the same problem, did you find a fix for this? ... not support audio output, then you need to add a Bluetooth adapter which includes a CD driver.
JBL Charge 2 ' Portable Bluetooth Speaker with USB Charger
www.jbl.com > Wireless > Portable Bluetooth Speakers
JBL
Rating: 4.3 - ‎110 reviews
Most popular JBL Charge 2 wireless portable speaker can charge any devices via USB... You can easily connect Charge 2 to any Bluetooth-enabled device by giving the portable's ..... Charge with proper charger or a USB port form computer.
If U Charger The Jam 2 When It's On Low Battery In The Outlet and And The Red Light Doesn't Show What Should I do?
Doesn't sound like it's charging. Have you checked the charging pin to Mack sure it's intact. Try another micro usb charging cord too,!
HMDX Jam wireless speaker cannot be paired with my computer
Go to your Bluetooth settings, go to the "Audio/Video" tab, under the "Content Protection" section uncheck the "Connect to content protection enabled headset only" and your bluetooth speaker(s) should now work.
 Grubhead
Grubhead
SmartAviator
SmartAviator
