Drills Logo
Bradley Posted on Jun 09, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can i charge a 18volt ryobi battery on a 14.4volt charger
Russ Hill
Level 3:
  • Master 4,057 Answers
  • Posted on Jun 09, 2018
 Russ Hill
Master
Level 3:
Answers
4057
Questions
10
Helped
1177778
Points
12696
You can but it will take longer to charge and prob will be at 16 volts give or take 1 volt.
john h
Level 3:
Top Expert:
  • Ryobi Master 29,494 Answers
john h
Ryobi Master
Level 3:
Top Expert:
Answers
29494
Questions
0
Helped
7559560
Points
193449
I dont think the 14.4 charger accepts the 18
5 Related Answers
Anonymous
  • 7 Answers
  • Posted on Jun 11, 2009
SOURCE: can i charge a 14v battery using a 18v charger (both are ryobi)
Absolutely not. The risk of damage to the battery is only a minor concern compared to the fire hazard you would be creating.
Anonymous
  • 1124 Answers
  • Posted on Jul 31, 2009
SOURCE: light on ryobi 18v charger
More than likely a defective battery sinse the other ones charge fine..
Bring it back for exchange of another one..
Note;
We are helping people here every day on a points system.
If the information provided here was at all helpful,
please be kind and rate well.
Thank you – and enjoy your day ;o)
Anonymous
  • Posted on Nov 30, 2009
SOURCE: Ryobi p111 charger -- light stays red
My charger do the same thing. I talked with the service people at Ryobi who said that the red led never goes out no matter how long you charge it. They suggested just charge it for 12 hours and then disconnect. Pretty dumb system, but that's apparently the way it is.
Anonymous
  • 8 Answers
  • Posted on Apr 01, 2010
SOURCE: Will the ryobi nicad charger also charge the
No, but the Lithium charger will charge the NiCads.
Anonymous
  • 127 Answers
  • Posted on Dec 27, 2010
SOURCE: can you charge ryobi lithium batteries in a
NO! Never charge lithium batteries in a charger designed for nickle based batteries like the NiHi your old charger was meant for. Ryobi did design the new Lithium charger to be backwards compatible so you can charge your older 18V NiHi batteries in the Lithium 18V charger.
Also note, NEVER miss-match the voltage, for example, make sure you are not trying to charge 12V batteries in an 18V charger unless the manufacturer has specifically stated that the charger is capable of multiple voltages.
Ryobi 18v battery is fully charged, meters 19v, but won't work in any tool
Faulty battery.
A fully charged Cryobi 18volt battery reads about 21.5volts.
Can the drill be permenantly kept charging to be ready if needed
Hi there. I would not suggest that you leave it on charge, as you may burn the charger, or pop the battery. These units are very sensitive and should rather be charged and battery removed, so that no current is drawn from the unit, and when needed, the battery can be fiitted and ready to use. The charge however will also not stay in the battery for longer than a month or so. Hope this helps
New drill batteries wont hold a charge also, Bought a new battery screwdriver, the charger has exploded within 1 week
Don't even bother to try repair either of them, Take them back to the dealer under warranty and make them his responsibility, If you try repair them the warranty will fall away.
Ryobi p103 battery charged but dosen't work.
You need to have the charger tested, if you know that batteries are good then what else could it be. This LIon charger has a logic circuit in it like a computer.
18volt ryobi battery charger doesnt work
try pitting battery in charge and wiggle the battery a little to see if the green light comes on, sometimes the make contact and then loose it when you let go of the battery.if still same problem charger is probbly dead.
1helpful
2answers
Can a bad ryobi 18 drill ruin a new 18volt ryobi battery
If the drill has a short in it, then yes, it could short the battery out. Probably in the trigger switch.
3answers
Battery charger model 1400666 not charging The red led is not on.this is a 12 volt charger.
I have two 18volt chargers doing the same thing. I have had them apart and it seems to be the transformer not pushing any power thru. If you can find a transformer that fits and has the right voltage that should fix the problem. From what I can make out if you leave the battery in for too long on charge it cooks the transformer. Hope this helps
Top Ryobi Drills Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
