So, it sounds like the bobbin thread is coming to the top of the fabric and the top thread simply lays on top of the fabric. Just a hint: If the thread problem appears on top of the fabric, it is usually a bobbin thread problem. If the thread problem appears under the fabric, it is a top thread problem.
Is the top thread tight, ie pulling the bobbin thread up? Try loosening the top tension.
If that doesn't resolve the problem, then you probably need to tighten the bobbin tension.
Understanding Thread Tension on Your Sewing Machine
SOURCE: material is puckering.i was hemming pants ,that
you should always use needles that are the right size and sharpness for different fabrics. any fabric store can help you with this. according to your machine the smaller the # on the needle the finer teh fabric it will sew. also using the right weight of thread is important...light weight thread for light weight fabric and heavier for thicker fabrics
