If your have faced this issue while using your computer. Then you need to follow these steps to fix UI Failed to Load on windows
https://www.mygeekshelp.com/avast-ui-failed-to-load-after-windows-10-update
SOURCE: I have a crystalview xt android tablet or PC and my system UI stopped working
• You need to switch off your tablet
• Then press/hold power+volDOWN+home just keep pressing it
• Then it will switch on with a word start in it let go of the buttons you are holding
• You need to click on the VolDown twice so a recovery mode will appear.
• You need to click power so it will restart to recovery mode
• An android image will appear that has a red exclamation mark
• After which you need to hold down power and then press VolUP
• You need to use volume to scroll and press power to select "wipe data/factory reset"
• Then you need to scroll down again and press power to select "yes-erase all user data" This will now start your tablet to reboot Then it will switch off then switch on again.
