Already update controller and firmware, print 1 card well then you hear mechanism rotate as 2 times trying to get ready and nothing marks mechanism error, I open the lid where the cards are, I close it and it gets ready, reprint 1 card well and again the same, some idea, thank you
SOURCE: error message
Issue related stuck due to objects such as paper or plastic. make sure its clean and gears are moving.
Good luck
SOURCE: I have a zebra P330i
My solution was the cleaning roller. Zebra said the roller was not getting enough pressure to pull the card through. I pressed the metal clips down to give more tension and the printer works great now.
SOURCE: Zebra P240i will not print test card or feed cards
i need the cardfive driver for my zebra P420i card printer.
SOURCE: evolis pebble 3 displays mechanical problem error?
Clean all rollers
Check if print head is mounted properly
