SOURCE: Toshiba DKT 2020 Telephone
Your voice mail may have broken. If it's based off a hard drive the hard drive may have died on you. You may need to get a local company to come out and troubleshoot the problem.
SOURCE: answering machine wont pick up it just cuts off incoming call leaving line busy
just set the amount of rings higher on the back of the phone and make sure all you old messages are deleted and also make sure its not set to do not disturb
SOURCE: Voicemail
It sounds like you are using a voicemail service from a provider, meaning you did not buy the voicemail system with the phone system. If you confirm, I can tell you how to fix this.
SOURCE: panasonic kx-t7330 suddenly cannot use intercom and phone calls
I'm guessing the phone is 8 years old and you spilled something into the keystrip.
Start by unplugging it to see if it resets. Then, look for a mechanical failure (sticky buttons, broken buttons, etc.). Some alcohol and a Q-Tip will clean the buttons, or carefully take the phone apart and wash out the housing.
Last, but not least, any of the new 7730/31/35/36 phones will replace that set.
Carl
SOURCE: kx-dt333 phone rings, red light
You can press the softkey under RingOff and the up arrow on the Navigator button, or just press the up arrow on the navigator button two times. The display will show the ringer volume level as you continue to press the up arrow.
Carl
