SOURCE: how do I raise the feeder feet
There is a slide switch on the underside of the back of the free-arm. The feed dogs will not immediately raise when you slide it, the machine must make a full rotation for it to engage.
SOURCE: Elna 6003 just stopped working
I need a manuel for a Elna 6003 quilters designer where can a purchase one???
SOURCE: need a manual for Elna 6003 Quilters Dream sewing
Here is one - http://cgi.ebay.com/ELNA-6003-QUILTERS-DREAM-INSRTRUCTION-MANUAL-50-PGS_W0QQitemZ260342126317QQcategoryZ41246QQcmdZViewItem
Testimonial: "I am so pleased that I was able to get my manual and now know how much I can do with my machine. Keep up the good work. We all need to work together."
SOURCE: When the machine starts the
Sounds like the bobbin case has shifted inside the rotary hook area. Have you got the manual? if so, does it give directions to remove the bobbin case as part of the cleaning instructions? If you have never taken it out, perhaps take pics with your digital camera to help you put it back in correctly. It is held in by a magnet underneath it. Remove the needle plate, pressure foot and needle, and the bobbin.
Have a good look at the bobbin case, it should have a stopper which sits against a little bump and might have two red marks to line up correctly. Are these lining up or has it shifted a little. If so, then lift out the bobbin case by holding the edge closest to you and lifting it upwards and towards you. Brush the underneath area out carefully to remove any lint or thread bits with your little brush bringing the lint out of the area and into a bin (dont push it around into the area under the rotary hook) and don't blow it out with air. Have a good look at the bobbin case too and check it for any damage, if you dislodge it while stitching the needle can strike it and as its plastic there may be little marks or bits of plastic now, if so, give them a gentle rub with fine grade sandpaper (away from the machine works) or a nail file to smooth off. I found that mine had a couple of holes and the thread was then catching on the rough edge of plastic and jamming constantly. I actually bought a new bobbin case after 3 goes to sort this out.
Now put the bobbin case back into place, lining up the red marks if it has them. Manually turn the flywheel towards you through a stitch sequence, the holder should sit still while the hook goes around it.
Reassemble the machine, rethread and test sew. I hope this helps, if you have tried all this already, then perhaps take it to your Elna dealer for further investigation/service.
SOURCE: I would like to oil my elna 6003 but the manual
I'm pretty sure these have a wick in the rotary hook under the black plastic bobbin holder where the bobbin sits. Everything else is nylon gears or designed to be lubed during your annual recommended service by an Elna technician.
You can oil the wick yourself (don't do what I did and pull it out with tweezers, dooh). Take out the bobbin holder black bit (your manual should cover this in cleaning) and see if there is a depression/hole in the middle of the metal rotary hook. If so, just put a drop of oil in there once every couple of months.
More important is to clean out the rotary hook well regularly and everywhere else in there, just use the little brush to collect the lint, then wipe it off on a piece of cotton fabric waste to clean the brush, then clean a bit more until no lint remains. Now put the bobbin holder/case back into position lining up the marker point against the stopper. Done.
Hope this makes sense to you and matches what your machine looks like. Happy Sewing, Tally Girl
