The error is Please restart the program and/or switch the device off, then switch it on and wait while it warms up. Following those instructions does nothing. I restored the computer to a time before the update and the scanner again works again so the problem was caused clearly by the Windows 10 update.
I have the same issue, but I found a workaround. Open your start menu and search for the Windows Fax and scan app....open it (have your Dell connected), if you choose the scan option, the scanner on your Dell will act as the scanner...works for me, found this by chance just messing around!
On the off chance that something ends up earnestly with your Dell printer, you attempt to fix it segregated or you go in neighborhood direction which you reliably find exorbitant and not 100%. In this manner, we brief that you can get called "One Search Point" gave by us. We offer a snappy number that you can call and exchange with the Dell authority on the telephone and talk about the issue with your Dell printer. Inside a moment, your stress will be comprehended and on the off chance that it requires further support, by then you are given that in addition
Dell Printer Support Phone Number.
https://www.onesearchpoint.com/dell-printer-support-phone-number/
Well;, do go to dell.com, hint1, fixya is not DELL, ok?
and reload the printer software from scratch.
we all know windows forced updates can be bad
what I do use turn off driver updates.
ends the pain.
I have pro w10., and can delay many other updates for 3 month.
this is so I dont get 1/2 backed updates,
learn how to turn off driver updates.
Is my big hint.
ever like read the the first page
I guess this is your printer,l right.
http://www.dell.com/support/home/bg/en/bgbsdt1/product-support/product/dell-1133/research
it says clear as day "w10 not supported"
but then again I do not have your full service tag data facts
only the words 1133 to go on.
that can mean it works one day and the next
or not at all
or not for the next w10 update.
easy no?
if I found the wrong printer, then you go there and answer dells questions fully, and then land on exact facts exact models.
SOURCE: MFC-420CN scanner error
This might be a hint: http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000100/000082/faq000182_001.html?reg=us&c=us&lang=en&prod=mfc420cn_us&Cat=8 another one is this: http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=mfc420cn_us&type2=6&flang=English&dlid=
SOURCE: Error During Scanning
Please check whether any other scanner is installed or not .It might be creating the conflict.
Pls remove it.
Haoppy scaanning
Omnipresent
SOURCE: Won't scan nor fax
HP multi units are notorious for scanner failures. It is just a weak component in their machines. I have seen this time and time again. The only solution is to change the scanner out or purchase a different machine. Just keep in mind the notoriety HP has which failed scanners. If you want to venture into the replacement of the scanner the following website might have the product you are looking for. Otherwise, search around the net for a scanner assembly unit for the OJ7310. But, be prepared scanner units are not cheap.
Check here first...PrinterFixer.net
SOURCE: Scanner error in HP officejet Pro L7590
These instructions will fix the majority of scanner problems and networking problems using ethernet:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01849855&lc=en&dlc=ro&cc=ro&product=3643612&rule=4124&lang=ro
The key is to assign a static ip address for the printer. The install problems of trying to get the HP printer to be found will go away. You can then use the scanner. Also...it is crucial that when connecting other laptop's and PC's on the same network that you use the hp printer'rs host name to find the printer on the network. I find that the IP address can and usually fails to find the hp on the network. Mostly likely you cannot search the network for a hp printer until you go the route of find the hp network printer with the host name of the printer. You will also need your install disk when installing on other networl laptop's and PC's since windows xp and Vista machines don't have the drivers in the list. You will need to point the add printer gui driver to the disk and look for autorun.inf
file. After selecting that file...you can then see your drivers.
