The saw was working fine. I shut it off. When I attempted to pull the cord to start it again, the cord would not retract. I removed the cover, disassembled everything related to the cord. Made sure the...
Many of these small saws have what is reffered to as an e start, the section that engages to the flywhell is seperate to the rope pulley, and is joined via a round coil spring, the idea is to soften out the compression and help to spin the engine over when cranking, one end of the spring fits into the outer flyheel engagment pinion, the other ends fits into a hole in the starter cord pulley, it does not fit into the main recoil spring, the securing screw for the assembly is a shoulder screw the idea is not to pinch the rewind mechanism when tightened, as this only screws into plastic it is very easy to over tighted and make the pulley post swell and stop the pulley rotating on the shaft, you may now need to leave the screw just a little slacker, the black plate under the starter is a conductor plate, this helps blow the cold air from the flywheel over the cylinder, this plate should always be there. When assembling the starter on the saw, keep pulling the rope as the cover goes on, this will ensure the pinion engages properly with the flywheel pawls.
Hi Adrian wait, I want to help you with your question, but I need more information from you. Wow, gas powered circular saw? Not a cement cutter? Brand and model will help.
